Well, after receiving my Vbox, of course I immediately went out and did some testing.
The piece of land used is completely flat and straight, posted below.
I used the center lane each time, I started around 5500RPM or approx 40Mph I believe in 2nd, and floored it.
Car Setup
- Tune = 93 GIAC Stage II
- Gas = 94 PetroCan Ultra In Tank
- DA = -800 according to drag times
Runs
1st Pass No Methanol - 11.85
2nd Pass No Methanol - 11.7
3rd Pass Light Spray - 11.4
4th Pass Light Spray - 11.2
Also, the bypass valve issue is killing me, some runs I am seeing boost drop to 10-11 Psi by redline, GIAC needs to do some cold weather testing!!!
I am reading boost from the analog hookup on a P3 gauge connected to the Eurocode boost tap.
You would be surprised what is completely flat. Even our track isn’t completely flat. It’s pretty close though. I believe we have around a 0.1% decline in the northbound direction and a slight incline in the southbound run.
