VCDS help with lights...
Guys Ive been doing vagcom mods on cars for years but Ive screwed the pooch on my S4 2014 I must have inadvertently changed something because now I keep getting that my left and right DRL is out. Attached are the mods I made if someone can sort this out for me or provide me screen shots of their modules in stock settings Ill just go back to stock.
http://i62.tinypic.com/2i6dugw.jpg
http://i62.tinypic.com/2cnwayr.jpg
http://i62.tinypic.com/4qt0tl.jpg
Thanks Guys,
Migo
Bit 4 of byte 2?
Go into that module and run a readyniess test that way got can see if there is actually a fault. You can also do a our put test that will help get you in a direction of knowing what’s wrong.
Un-check the box labeled bit 4 (drl via separate running lights active) and u should be gtg.
Ad
