This is what I found on the Zine.
Can We compile a list for our platform?
VCDS & Hidden menu: The complete list
Here’s the list I’ve compiled so far:
Disable After-wipe of windscreen wipers
Disable amber corner lights
Disable amber side markers
Disable Key warning (keyless models)
Disable LED ‘wink’ on turn signal
Disable “Lights are on” warning
Disable NAV & Phone warning messages while entering data at speed
Disable Seatbelt Chime
Enable Adaptive brake lights
Enable Ambient Interior Lighting Control
Enable Automatic Gear selection shown in DIS
Enable Automatic Hill Hold Assist ‘lite’
Enable Auxiliary ventilation
Enable Battery meter
Enable DIS with Efficiency Program
Enable Double Disarm Beep
Enable DRL Selectable via MMI
Enable DRL
Enable Euro parking lights that turn on signal at night
Enable fog lamp to come on for the same side as that turn signal
Enable Front Turn Signals as Parking lights
Enable Gauge Test/Needle Sweep
Enable Hidden menu in MMI
Enable Import CDs to MMI’s HD
Enable Independent Fogs control with high beams
Enable Lap Timer
Enable LEDs remain bright for parking lights
Enable Rear Tail Lights on with DRLs
Enable Release Parking Brake without putting foot on Brake
Enable Release Parking Brake without putting seatbelt
Enable Remote Operation windows&sunroof
Enable Reverse mirror tilt
Enable Speed through MMI
Enable TPMS
Enable VIM on MMI
Set Audi parking system - Switch OFF Speed
Set Custom ADS settings
Set Headlight washer - cycles
Set Headlight washer - duration
Adjust Consumption in DIS
Adjust LED Brightness
Audi A4/S4 B8
VCDS (VAG-COM) codes
[09 – Cent. Elect.] [Coding - 07] -> [Dropdown] -> “x ** 8K1 955 119 ** WWS xxxx” -> Long Coding Helper -> Byte 1
Bit 3 - Remove check mark (1 = active)
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 10
Submodule 0
Bit 3 - Set to 0 to disable amber side markers (U.S. vehicles)
[46 – Central Conv.] [Coding - 07] -> Long Coding Helper -> Byte 9
Bit 7 set to 0 (Uncheck)
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 3
Bit 2 - LEDs remain at full brightness with parking lights (1 = active)
Bit 7 - Turn off LED-strip DRLs with indicators (1 = active)
Disable “Lights are on” Warning
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 5
Bit 3 - Set to 0 to disable “lights are on” warning when you open the door.
[5F - Information Electr.] -> Adaptation -> Set channel 2 & 3 to 250
[17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 0
Bit 2-4 – Seat Belt Warning inactive
[46 - Comfort System] [Coding - 07] -> Long Coding Helper -> Byte 8
Bit 0 – Emergency Brake Flashing via Turn Lights active (1 = active)
Bit 1 – Emergency Brake Flashing via Brake Lights active (1 = active)
[Hidden menu] [car] [carmenuoperation] [interior light] Set to 5
[Hidden menu] [car] [cardevicelist] [interior light] Enable
Reset MMI
[02 – Auto Trans] [Adaptation – 10]
Select “Single Gear Display” from top channel drop down menu
Select “D on/S on” from New value drop down menu
[03 - ABS brakes][Security Access - 16] (Enter code presented by program)
[Coding – 07] -> Long Coding Helper -> Byte 1
Bit 6 set to 1 to enable hill hold assist.
http://www.audizine.com/forum/showth...r-the-A4/page2
[5F - Information Electr.] [Coding - 07] -> Long Coding Helper -> Byte 6
Bit 1 – Set to 1
[Hidden menu] [car] [cardevicelist] [Auxiliary heating] Enable
[08 - Auto HVAC] [Coding - 07] -> Long Coding Helper -> Byte 1
Bit 3 – Set to 1
Bit 4 – Set to 1
[Hidden menu] [car] [cardevextdevicelist] [Battery] Enable
[Hidden menu] [car] [carmenuoperation] [Battery] Set to 5
Reset MMI
or
[56 - Radio] -> Adaption -> Channel 39, add 16 to your value
Enable DIS with Efficiency Program for MY2010+ (Not a complete Program without the Start/Stop System)
[17 - Instruments] [Adaptation - 10] -> Channel 77
change 0 to 255
[46 - Central Conv.] [Adaptation - 10] -> Channel 63
Add 4
[09 – Cent. Elect.] -> [Coding – 07] -> Long Coding Helper -> Byte 3
Bit 5 set to 1
Enable DRL
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 2
Bit 1 = DRL via Front Side markers
Bit 2 = DRL via High Beams
Bit 3 = DRL via Fogs
Bit 4 = DRL via LEDs
Bit 6 = DRL via Side markers
Bit 7 = DRL via Tail lights
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 9
Bit 0 - Set to 1
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 4
Bit 0 - Check the box or change :Bit 0 set to 1
Bit 0- Check the box or change :Bit 0 to 1
Once the change has been made you can enable the front turn signals as DRL’s by making the following change:
Bit 6 - Check the box or change :Bit 0 set to 1
[17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 1
Bit 0 - Check the box for “Gauge Test/Needle Sweep active”
Enable Headlights on all the time
Bit 5 - Check the box or change :(Bit 5 Set to 1)
change 0 to 1
Use this hidden menu at your own risk.
Caution: Keep away from the “Bootloader”
[Hidden menu]
Main/Diagnose/Settings
Import Media
Set to 4 of 4 “Copy/Ripping”
Bit 1 – (Front) Uncheck the box or change :Bit 1 to 0
Bit 2 – (Rear) Uncheck the box or change :Bit 2 to 0
Enable Lap Timer
Bit 3 - Check the box for “Lap Timer active”
Enable Remote Operation Windows and Sunroof
[46 - Cent. Conv.] [Coding - 07] -> [Long Coding Helper] Byte 2
Bit 2 - Set to 1
Bit 7 - DRL’s via Tail Lets Active (1 = Active)
[53 - Parking Brake][Security Access - 16] (Enter code presented by program)
[Adaptation - 10] -> Channel 4 Set to 0
[Adaptation - 10] -> Channel 7 Set to 0
[52 Door Elect, Pass.] -> [Coding - 07] -> [Long Coding Helper] -> Byte 4
Bit 4 and Bit 2 set to 1
[56 - Radio] [Adaptation - 10] -> Channel 02, Set to 1
Does not work if NAV equiped
Enable TPMS
- You need the 1AT ABS unit – check your stickers (1AS does not work)
[Hidden menu] [car] [cardevicelist] [RDK] Enable
[Hidden menu] [car] [carmenuoperation] [Tires Air Pressure Control] Set to 5
[03 - ABS Brakes]
[Security Access - 16] (probably with login code: 61378)
Bit 3 - Tire Pressure Monitoring (PR-7K6) active (1 = active)
The TPMS need to be enabled in the Instrument Cluster:
[17 - Instruments]
Bit 0 - Tire Pressure Monitoring (TPMS) installed (1 = active)
Reset MMI
Enable VIM on MMI
[5F - Information Electr.] [Advanced ID - 1A] Note 1st Serial number
[Security Access] Enter Digits 6, 13, 10, 14, 11 of the 1st Serial number
[Adaptation - 10] -> Channel 48
Set to 255
Reset MMI
[10 - Park/Steer Assist] [Adaptation - 10] -> Channel 23
Set to 20 (max value in km/h)
Set ADS to specific preset Comfort, Auto, Dynamic or Individual
[09 – Cent. Elect.][Security Access - 16]
Set to 01 - Comfort, 02 - Auto, 03 - Dynamic or 04 - Individual
[Adaptation - 10] -> Channel 64
[Adaptation - 10] -> Channel 65
[Adaptation - 10] -> Channel 66
*Note all four channels needs to be set to the same value.
Set Headlight washer - Duration
[09 – Cent. Elect.]
[Security Access - 16] [Adaptation - 10] -> Channel 6
change to e.g. 500
Set Headlight washer - Cycles
[09 – Cent. Elect.]
[Security Access - 16] [Adaptation - 10] -> Channel 26
change to e.g. 10
[17 - Instruments]
[Adaptation - 10] -> Channel 3
change 100 to xxx (see samples below)
Sample 1 - Calculation based on volume per distance (e.g. l/100km):
DIS: 9,3 l/100 km.
Real: 9,8 l/100 km. (100 * 9,8 / 9,3 = 105,38)
Channel 3 will be changed from 100 to 105
Sample 2 - Calculation based on distance per volume (e.g. MPG):
DIS: 23 MPG.
Real: 24 MPG. (100 * 23 / 24 = 95,83)
Channel 3 will be changed from 100 to 96
Adjust LED brightness
[09 – Cent. Elect.] [Security Access - 16] (enter security code. One of the default codes is- 20113)
Set between 5 and 100
Again, I take no credit for this information, most of the above is available on these forums and specialty websites as well as Ross-Tech’s support pages. I only wanted to group all the info of the pertinant VCDS mods to our S4.
Not all the above has been verified, I’ll be happy to re-edit this post to correct any info.
Oh and I’m not responsible for any screw ups this causes, good luck.
