VCDS newbie.
just found some time to finally install vcds and see what codes my car is throwing looks to me like o2 sensors and intake manifold flap. it says something about a fault in the se3cond computer, how do I scan the second one?
I"ll post the entire log below, I just did the autoscan and this what I got.
Thursday,11,September,2014,21:27:16:00498
VCDS – Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WUARU78E57N900137 License Plate: BRCY297
Mileage: 151060km-93864mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WUARU78E57N900137 Mileage: 151060km/93864miles
Address 01: Engine Labels: 079-910-560-BNS1.lbl
Part No SW: 8E1 910 560 A HW: 8E1 907 560
Component: 4.4L 91/V6 JHM ª0060
Revision: --H09— Serial number: XXXXXXXXXXXXXX
Coding: 01040009180F0160
Shop #: WSC 93008 999 83881
VCID: 2447CDB6E7DA0D3EDFF-8071
5 Faults Found:
008213 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 - 008 - Implausible Signal - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101000
Fault Priority: 0
Fault Frequency: 56
Reset counter: 255
Mileage: 149198 km
Time Indication: 0
         Freeze Frame:
                RPM: 762 /min
                Load: 22.3 %
                Speed: 0.0 km/h
                Temperature: 39.0°C
                Temperature: 26.0°C
                Absolute Pres.: 960.0 mbar
                Voltage: 13.589 V
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0036 - 004 - Malfunction / Open Circuit - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100100
Fault Priority: 0
Fault Frequency: 179
Reset counter: 255
Mileage: 150389 km
Time Indication: 0
         Freeze Frame:
                RPM: 775 /min
                Load: 16.5 %
                Speed: 0.0 km/h
                Temperature: 101.0°C
                Temperature: 45.0°C
                Absolute Pres.: 970.0 mbar
                Voltage: 13.716 V
004372 - Oxygen (Lambda) Sensor; B1 S2
P1114 - 008 - Internal Resistance too High - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 150793 km
Time Indication: 0
         Freeze Frame:
                RPM: 1869 /min
                Load: 17.2 %
                Speed: 49.0 km/h
                Temperature: 93.0°C
                Temperature: 34.0°C
                Voltage: 13.335 V
000313 - Oxygen (Lambda) Sensor B1 S2
P0139 - 004 - Response too Slow - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 150827 km
Time Indication: 0
         Freeze Frame:
                RPM: 1920 /min
                Load: 17.2 %
                Speed: 50.0 km/h
                Temperature: 93.0°C
                Temperature: 34.0°C
                Voltage: 13.208 V
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 151064 km
Time Indication: 0
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 88.0°C
                Temperature: 63.0°C
                Voltage: 11.811 V
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 G HW: 8E0 614 517 BD
Component: ESP8 quattro H06 0150
Coding: 0004533
Shop #: WSC 06335 000 00000
VCID: 2B55268A8A04C2461E5-807E
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 2832
Coding: 00000
Shop #: WSC 00000
VCID: 6DD1E89227900C76401-5106
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul USA 0704
Coding: 01023
Shop #: WSC 65536
VCID: 3B7516CA296452C68E5-4B1A
Address 11: Engine II Labels: 079-910-560-BNS2.lbl
1 Fault Found:
004416 - Oxygen (Lambda) Sensor; B2 S2
P1140 - 008 - Internal Resistance too High - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 24
Reset counter: 255
Mileage: 149297 km
Time Indication: 0
         Freeze Frame:
                RPM: 6660 /min
                Load: 79.2 %
                Speed: 175.0 km/h
                Temperature: 92.0°C
                Temperature: 31.0°C
                Absolute Pres.: 950.0 mbar
                Voltage: 12.319 V
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H12 3840
Revision: 91H12384 Serial number: 0036N001NW35
Coding: 0433607
VCID: 3C7715D67F6A55FE87F-8069
Subsystem 1 - Serial number: 6332DRB402E04C26N
Subsystem 2 - Serial number: 6342DRB402E490B1P
Subsystem 3 - Serial number: 6352ARB401097FDC$
Subsystem 4 - Serial number: 6362ARB401088E58R
Subsystem 5 - Serial number: 63729RB4010A70258
Subsystem 6 - Serial number: 63829RB4010A70406
Address 16: Steering wheel Labels: 8E0-953-549-T.lbl
Part No: 8E0 953 549 T
Component: Lenksáulenmodul 0201
Coding: 04441
Shop #: WSC 06335
VCID: 44876D36549A2D3EFFF-4B00
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 931 G HW: 8E0 920 931 G
Component: KOMBI+WFS 4 H14 0030
Revision: 0030 Serial number: 00000000000000
Coding: 0023301
Shop #: WSC 93204 999 85775
VCID: 2C5725968C0AC57E17F-5140
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0023301
VCID: 2C5725968C0AC57E17F-5124
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 00000
VCID: F1E974E2BBA86896E49-4B00
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 J HW: 8E0 035 192 J
Component: RNS-E US3 H72 0200
Revision: 03S Serial number: AUZBZ7F2428587
Coding: 0309617
VCID: 2B55268A8904C2461E5-517C
2 Faults Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 1
Reset counter: 216
Time Indication: 0
Date: 2005.08.26
Time: 00:00:35
         Freeze Frame:
                Voltage: 12.40 V
                Mileage: 655350 km
                Count: 65535
                Clock: 255:255
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 254
Reset counter: 215
Time Indication: 0
Date: 2012.08.10
Time: 06:37:42
         Freeze Frame:
                Mileage: 655350 km
                Count: 1109
                Clock: 20:16
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CG
Component: Komfortgerát T7B 4035
Coding: 11900
Shop #: WSC 06335
VCID: 78FFC9C658D2B9DEA37-4B00
Subsystem 1 - Part No: 8E1959801G
Component: Tõrsteuer.FS BRM 0706
Subsystem 2 - Part No: 8E1959802G
Component: Tõrsteuer.BF BRM 0706
Subsystem 3 - Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
1 Fault Found:
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000019
VCID: 285FD9869BF2E95EF37-807D
Subsystem 1 - Part No: 8E0 941 329
Component: AFS-Modul links H03 0020
Subsystem 2 - Part No: 8E0 941 329
Component: AFS-Modul rechtsH03 0020
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0309617
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 216
Time Indication: 0
Date: 2005.08.26
Time: 00:00:35
         Freeze Frame:
                Voltage: 12.40 V
                Mileage: 655350 km
                Count: 65535
                Clock: 255:255
Freeze Frame:
Fault Priority: 5
Reset counter: 215
Time Indication: 0
Date: 2012.08.10
Time: 06:37:42
         Freeze Frame:
                Mileage: 655350 km
                Count: 1109
                Clock: 20:16
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 A HW: 8E0 907 273 A
Component: Reifendruck 3 H04 0130
Coding: 0062523
Shop #: WSC 93008 999 59057
VCID: 2A5B238E86FEDB4EE53-515E
2 Faults Found:
01521 - Sensor for Tire Pressure
002 - Lower Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 3
Fault Frequency: 4
Reset counter: 40
Time Indication: 0
         Freeze Frame:
                (no units): 130.0
                Voltage: 13.60 V
                (no units): 19.0
                    Not Recogn.
                    Not Recogn.
                    Not Recogn.
                    Not Recogn.
01833 - Antenna for Tire Pressure Monitoring; Rear (R96)
004 - No Signal/Communication - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 14
Time Indication: 0
         Freeze Frame:
                (no units): 21.0
                Voltage: 13.40 V
                (no units): 130.0
                    Not Recogn.
                    Not Recogn.
                    Not Recogn.
                    Not Recogn.
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 D HW: 8E0 919 283 D
Component: Parkhilfe 4-Kan H06 0010
Revision: 00H06000 Serial number: 00067802020605
Coding: 0000304
VCID: 316934E2AB28A896249-515E
1 Fault Found:
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 91
Time Indication: 0
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 G HW: 8P0 862 335 G
Component: FSE_255x BT H21 0190
Revision: 00000001 Serial number: 00000000411328
Coding: 0011877
VCID: 3A7B13CE765E6BCE953-5124
End --------------------------------------------------------------------
