Does anyone have or know where i can get some of the missing label files for ross-tech vcds for S6 C6. The label file helps with the measuring stats in knowing what is being measured. Ross-Tech has some label files included but are missing a few for this model. Mainly its missing the engine channels (1-3) label files.
Hi Craneium. For the less knowledgeable (like me), would you mind providing links to the label files you do know about for this car?
I renamed the three label files for the R8 to match the missing ones for the S6 and it worked out ok.
This was over three years ago so I do not remember the filenames but if you do a bit of searching in the Rosstech forum, you should find it pretty quickly.
The label files are located in your sub folder in the ross tech stored on your C drive. You can change them by hand if you wish.
You can contact ross tech and ask them for an update.
Did that help.
