Video: Racing a Stage II B8 S4 in my Stage III B5 S4 - copied from vendorzine...
So I guess now we know a jfonz tuned “stage 3+” b5 s4 is a mid to low12s car. The saviour of the b5 platform. You’re able to send the b5 s4 backwards 5 years in progress, and get applauded for doing so by high schoolers everywhere .
To match that $10,000 build, a b8 guy got tune and exhaust. An rs4 could do so with tune and piggies.
Here’s what stage 3 b5 s4s used to look like. These cars would put a football field on that b5 and b8 in a race right through fifth.
http://www.streetfire.net/video/audi-s4-jhm-11-sec-run_145939.htm
Def not looking for an argument, more just asking for your opinion…
You really think an RS4 with just a tune and piggies can put up a fight with a Stage 2 S4? From looking at numbers it seems that even a Full JHM Bolt on car with 10k in mods is trapping around 111ish.
I would loveeeeee to do a pull with a JHM RS4, moreso excited to see results either way than bragging rights.
I see JHM 2.75" Exhaust, JHM 2.75" Downpipes, JHM Tune, K&N Drop-in, JHM Crank Pulley, JHM Phenolic Intake Spacers and a fresh carbon clean as a good running mid to low 12 second car…
Clutch, flywheel, short shifter and LW rotors f+r are needed eventually but I don’t think are essential for low 12’s since we’ve seen a sub 12.5 stock tune time I believe.
I would also say that that there’s probably closer to 15k into the B5 in comparison to the B8 which is around $3500 with a lot less labor needed in regards to the B8.
Ask tsivas27 :slight_smile: or yourself. Didn’t your dad’s tuned b8 barely pull on tony? He was basically stock.
Anyway I was referring to running mid to low 12s, not roll racing. Here…
Hell a couple of not-even-tuned rs4s went low 12s. Mistro went 12.4 @ 113.9 with piggies, intake spacers, hpipe (in stock exhaust) …that’s it. Oh and coilovers lol.
Jnaut went 12.2 on stock tune, catless downpipes, stock car back and a bunch of lightweight mods (flywheel, rotors etc) .
So yes I absolutely think it can be done.
I went 12.75 in the spring and 12.82 @ 109.9 last fall (I’m completely stock) and when I raced Mistro (jhm tune, piggies, spacers, crazy k pulley, hpipe) this happened…
https://www.youtube.com/watch?v=FQqVGnGLd7Q&feature=youtube_gdata_player
http://i375.photobucket.com/albums/oo193/sakimano/Screenshot_2013-07-29-08-36-18_zps3943279f.png
I ran Tony the other night (45? Roll) Did a few pulls. Couldn’t get any slower bc of area. Wasn’t close at all. His carbon clean is a few months old and his clutch finally is working and not sticking.
He basically asked if I had a new tune. Loving those JHM LW F/R rotors btw. Other than them- only thing that’s new is the CPS.
Saki- Video of Pete’s dad was with Pete as passenger (2 guys @ 250) vs Tony (165 soaking wet). Think they had him by 2-2.5 cars. Was when he was on Revo Tune.
We should have some good runs soon.
Jnaut had a lot of lightweight mods as you stated and was on 98 octane, both of which IMO probably have more of a positive effect on the car than the tune…
In fact out of the 4 top N/A RS4 times 2 of them are stock tune and 2 are JHM tune- the two stock tune cars are trapping higher. Granted ones on 98 and the other 94 but still…
When my dad raced Tony we were both in car and my dad was tune only. 510lbs in passengers vs. 160lbs. We still got him by 2-3 cars and that was when my dad wasn’t great with DSG and he would just gun it in auto mode (the car would take about a full second to downshift and the clutch to grab). Between that and the extra weight it would have been pretty ugly.
Tsivas raced Tony when Tsivas was stock and Tony had just the H-pipe and drop in filter. Dead even. I ran my dads old RS4 with his current car. My dads old car had 15k in carbon. I actually pulled about 1/2-1 full car.
I think Tony’s car pre-carbon and my dads old RS4 vs. my dads stock and S4 and Tsivas stock S4 is probably similar to your stock RS4 since you haven’t had a carbon clean up. So Mistro’s car probably pulled on yours the way he’d pull on a Stock S4. Me and Tsivas did a pull when I got my new car. He had me by atleast 10 cars I couldn’t even see him anymore and I’m a much better shifter and we went from 2nd gear on
The only way we can finally settle this, which is think needs to be done because between the S4 and RS4 I think we’re both pretty curious to see how we stack up is to just line them up. Me, my dad and Tsivas are ready…
You ran tony and beat him. What fuel were you running?
  1. Tony’s car is constantly broken, likely a result of his mechanic (himself). Is it really a strong running RS4?
  2. Tony’s car is untuned. Not really pertinent to this discussion
  3. Tsivas, you have an $8,000 modlist yes? Again, not part of this discussion.
  4. When you ran Paul’s RS4 last year, what happened?
I will post what I wrote again, because I can sense that you guys are urinating in your pants with anxiety.
[quote]So I guess now we know a jfonz tuned “stage 3+” b5 s4 is a mid to low12s car.
To match that $10,000 (B5 stage III) build, a b8 guy got tune and exhaust. An rs4 could do so with tune and piggies.
A JHM tune + piggies RS4 will most certainly hang with any tune and exhaust B8 S4 (a mid to low 12s car) in a quarter mile run. If you want an $8,000 modlist on the B8 S4 to make you feel better, that’s cool. Can I spend $8,000 on the RS4 too? if so, let me dial in a JHM Vortech V3 supercharger kit ($7900) + piggies (free). I will run in the 11s on california 91. Do you really think this is going to go well for the B8 S4?
So, to stay on topic, I will say again: tune + exhaust B8 S4 = tune + piggies RS4 = most stage III B5 S4 (K04 or equivalent turbos).
Sad (for the B5) but true .
  1. 93 Shell like I always do. Aside from the few sessions that I did for vbox 100 testing.
    1a. Tony’s car has 115k miles. Normal wear and tear items go. He uses same audi tech I use and he is def up on all the maintenance. His car runs fine. Recent carbon clean, Clutch grabs awesome, non sticky clutch pedal. Most of his problems recently were from his JHM clutch and LW crank pulley, and before that the carbon demon and some fuel pump/regulator stuff.
  2. Tony ran Paul a few times (2-3 iirc) with his current JHM setup (before he broke down) and he barely pulled on him.
  3. My mod list is ($1500 tune, $600 pulley, $1400 exhaust w/ stock dps, $1100 used CPS, $350 intake, $150 short shifter, $1450 rotors) ~ $6600.
  4. vs Paul? Think I won and I started in 3rd. Def not best comparison imho.
Only reason I mentioned Tony’s car is b/c my name was brought up above in regards to me running him and he’s only RS4 that comes out to do runs.
When Paul eventually comes out (I have been trying to get him out), we will post up those results also. I have no bias. You know that. Love the RS4. Besides… It’ll be better comparison as he has ~$8gs in similar mods.
anyone wanna guess what happened when i raced my car against a v10 r8 GT yesterday? lol
Why are some of you B8 guys getting bent out of shape…lol Saki was more or less taking a shot at the B5s and how shit they are now.
nah - at least I’ll speak for myself. Saki knows how much I love the V8. Pete does too.
Guess it’s more frustration trying to finally run a JHM car after all these months lol. It’ll happen soon. I’m gonna steal Paul’s car eventually. ;D
But yes… wrong thread to discuss. We will make an appropriate thread when time comes.
with the exception of a few outside of this thread, i think everyone in this thread so far has nothing but love for the v8’s i know i do, i had 2 of them
I like your shots at JHM and Paul. Those are thinly veiled and you may want to reconsider them.
I was not referring to you vs. Tony because as I said, he is not tuned and you don’t have ‘tune+exhaust’. Whenever that sinks in let me know!
I was referring to you racing Paul to 130 mph (when you had tune + exhaust) and being door handle to door handle. When he was barely modded… stock tune, he had stock cats and stock everything but tubi mufflers and maybe lw rotors.
And I was referring to Tony racing Pete’s REVO tuned DSG B8 S4 with AWE exhaust…when Tony was nearly stock. It was very close.
I know I know…it’s awful to hear that the RS4 is succesful. Sorry guys.
p.s. Euroswagr is the only guy to actually read the posts. Tsivas, Pete…you just blew up and went all anti RS4.
Paul is a grown ass man and has come out to your ‘racetrack’ a couple of times already. One time he put up a solid 60-130 time for an RS4 that is almost stock…and you guys left it off the list.
Another time he raced Tsivas when he was almost stock…and they tied to 130 mph…and Tsivas acts like it never happened.
Is it just me or is this not something Paul should bother with? the message is pretty clear. You don’t have an RS4 list. You have a B8 S4 list with Tony’s ailing RS4’s slow time on there.
So forgive me if I side with Paul on this. What’s the motivation for him?
All of you bitches should just go to the dragstrip (and yes Tsivas I’m talking to you…you went to the strip at least one other time and didn’t even run!). Don’t bother tripling the speed limit on a public road in an irrelevant test. The 60-130 is for tire mulching Supras and modified 996 GT2 drivers who can’t grip a fucking lick below 60mph. We drive quattro equipped Audis.
Def no shots intended at JHM or Paul. Sorry if you perceived them that way. I was simply stating what happened. Am I making it up? I am a big JHM fan- so don’t categorize me in that dept.
As far as race against him and Tony- I think that’s what you were referring to… yes I was initially behind them iirc as I started in a higher gear/lower rpms and eventually passed them both. He def wasn’t door handle to door handle at the end and we can agree to disagree on that scenario from 10 months ago.
As far as more recent pertinent results… I guess we will have to wait. Aside from the few pulls with Tony from the other night - I don’t have anything to go by.
Please don’t spin it into something it isn’t. I just report the facts and you should know that by now.
yes let’s hear it.
From a dig he should have crushed you.
From a roll he should have crushed you.
They run like JHM supercharged RS4s…low 11s at mid 120s. So much more potent than the V8 R8 or the normal V10.
The real shocker is the V10 plus. Basically an R8 GT with DSG. Awesome car.
well i came up on him and baited a little bit because racecar. two pulls both from 65-180. both outcomes exactly the same. i get a very quick jump and then about an instant 3 bus lengths lol but at 160 the gap wasnt increasing at all and remained the same but since he wasnt letting off neither did i haha. it sounded and looked like pure sex
Saki- couple of things before things get out of hand. I think you are misinterpreting some stuff.
again… I am not anti RS4. Don’t spin it into that either. Please ask Paul and Tony how much I love their cars.
As far as the 60-130 list… I don’t really care about that. Yeah it’s fun… but we probably do 20-30 runs cars against cars in lower speeds against the 3-4 times we report that night we pbox. I don’t care what he does for the list. I’d rather do a lower speed pull like others have suggested. Do you really think I want him out to just pbox? I asked him 100x to do pulls.
Who’s talking about tripling the speed limit? Last time we chatted with Paul… it was a 15 roll to something reasonable. Why wouldn’t he get involved in that? Motivation? He has a full bolt on RS4 that has done zero runs against willing and waiting cars. (M3, B8 S4s, B5 S4, u name it). Wouldn’t fantastic (non track) results even further the platform?
We are all grown ass men… Taking shots at me for not going to the track on a stock clutch. Come on dude. The one other time I went to the track LOL… ya with my 4 year old son in the back seat. Still waiting for those same RS4 guys around here to go also. Both on modified clutches. Include them in the “bitches” category. And I probably won’t go until I get a better clutch for my daily driver.
The RS4 time left off list wasn’t on purpose. I reported it to Pete and he said he had used an older list. Mistakes happen. He should have corrected.
Again… don’t spin things into something they aren’t. I report things just as they happen. And don’t include me in some blacklist of anti RS4/JHM hate. Far from the truth.
One thing that needs to be clarified: 2 JHM RS4s have been to the strip. Ever.
They went 12.28 and 12.29, and that was 2 full years ago. One was on 91 octane. They had tune/exhaust/clutch/lw crank pulley and rotors. Density altitude was in the 500-1000 feet range for the 12.28 car. Both cars were running early versions of the tune (these were the first two beta cars…Dan;s car and George’s car). One didn’t even have launch assist back then. George made 7 passes. Dan made 4 passes. Passes.
Saying anything about what a JHM RS4 can or can’t do is a bit premature, don’t you think? What did the fastest pump gas B8 S4 run 2 years ago when APR was on version 1 of their tune? Has the APR tune evolved at all since then? Guess what, so has the JHM RS4 tune.
As for race gas, it helps the RS4 limit timing pulled, but not much. Generally only in the heat. In the cold, it’s doing very little. Certainly not more than a tune (not even close).
Using the ‘JHM bolt on’ RS4 list to make deductions about JHM bolt on RS4 performance is not that easy…we have two times. If we looked at the first two B8 S4 times, we’d say that APR tune and lw mods and lw wheels and intake and catback only gets you 12.6 @ 110…because that was what voltron’s head ran before he sold his S4 and bought a CTS-v. In fact he didn’t even get out of the 13s the first time. Voltron would probably say ‘mods don’t do much on the S4’ based on his experience alone. We know that’s not anywhere near true of course…but it’s the danger of a small early development sample size.
p.s. my car is now carbon cleaned and I notice almost zero difference.
good god 180???!!!
that’s pretty cool he was keen to go.
That’s why I said all of you bitches. Plural. You all need to go. I don’t see what’s so scary about it. Does the B8 S4 clutch instantly explode when you leave a stoplight quickly? Because that’s all you need to do at the drag strip. Imagine you’re beside an RS4 that you want to beat and you see he wants to race at a light. What do you do…tell him to wait till you get some race gas, then go to the highway so you can go 60-130? Or do you just take off briskly then slam through the gears?
Driving 2 hrs to the strip to make passes in summer is fun, but not very useful. If I lived 2 hrs away I would NEVER go in the summer. I live 40 minutes away and I still don’t go (havenn’t gone this summer at all). I go in fall and spring.
If you’re wondering why these guys aren’t going to the strip, think about it. Paul will go in the fall. In his RS4. With his JHM mods. Will you? Or will you have eleven clutch stories?
