Sorry if this is a silly question but is it possible to warp your intake manifold and cause vacuum leak?
Backstory…i’ve been consistently getting CEL for lean at idle so i took it to a Euro mechanic to do a vacuum test. They told me that the intake manifold is warped causing the vacuum leak. They explained that the previous shop who installed the spacer didn’t put the manifold back together correctly causing it to get warped / damaged. They also told me the cost to replace is more that 1/2 of what the car is currently worth… this part i believe, the rest i’m not so sure.
is this possible or can the leak be fixed by replacing the manifold gasket?
