Hello all!
Joined a while ago, just getting around to all this
I think I have the same smell…but I think you have better luck than I do. I have not been able to drive the car, its been sitting in a garage, so it may just be remnants of the time this happened and hasn’t really been able to breathe.
On a 2007 S6,
Took car out one day and had a misfire, drove easy home and parked. Couple days later turned on, took for a ride. No VCDS at the time, used a normal scan tool to read codes. Came up misfires cyl4. Changed coil + plug on 4, started car - smoke poured out from around the reservoir but I couldn’t pinpoint it and there’s an odd smell, definitely some coolant, but cant put my finger on it because it smells off. More sour than coolant sweet?
Drove it about 20 minutes to the doctor. Would miss down low under load, probably when intake flaps open.
Stopped for a slice of pizza, left car running. Coolant poured out of the overflow while I was in the pizzeria. Had distilled water in car just in case. Filled up reservoir, drove to doctor, parked, appointment took an hour, started the car back up without losing coolant. Babied the car home, no issues with misfire I can pretty much make it happen on command.
Park car at home, coolant out of overflow…car has now been sitting. Car was carbon cleaned 2k miles ago along with OFH and vally pan gasket, various PCV hoses (done by shop) has its issues with oil leaks still.
Have not owned the car long. Definitely has VC leak and exhaust leak. Possibly OFH and front crank seal. I have since bought a VCDS Hex V2 and plan on scanning the car in the next couple days. The oil I think I can deal with, the misfire is a little too scary. Mech said engine is not hurt. Any ideas/guidance?
