Weight Reduction for C6 S6
Does anyone have links to light weight parts? I plan to lose 200+lb if possible on the car. Custom carbon seems to be a bit pricey so wondering if anyone was able to find or source anything for their car.
I have only seen a Chinese hood on Ali Baba…. Anyone able to find carbon hoods, roofs, or trunks?
Anything else worth while besides the wheels?!
IMG_3607|230x500
A Antigravity Lithium battery to start with will loose you 45lbs while keeping your same cranking amps. You can loose a couple pounds more by going with a few less amps and another $50~$100 but might as well keep the same amperage and it will keep the charging system (monitoring) happier.
Good Forged wheels, while not cheap will save you another 35~40lbs total.
