Background, this 2006 A4 B7 2.0T manual (160k miles) has been owned by me since new, the car purchased to bring my son home from hospital at birth (we had an Aviator grey TT 2.0 coupe previously), and the A4 is now his daily driver.
We have been having fueling issues for a few months, initially identified via VCDS full scan and while trying to add a JHM stage 1 tune.
The low pressure codes we were getting were two instances of the same code starting this thread 008 and 004.
012555 - Low Pressure Fuel regulation
P310B - 008 - Fuel Pressure Outside Specification - Intermittent - MIL ON
P310B - 004 - Fuel Pressure Outside Specification - Intermittent
So we immediately changed the LPFP, and there the saga started.
It is clear to me now that we had multiple problems related simply to age and wear because, for example, changing the HPF rail sensor solved a ‘cut out’ problem, but not the basic low pressure codes.
To date all the following have been replaced…
LPFP (VDO)
HPFP (Hitachi)
Fuel filter (x2 Hengst then genuine)
HPF rail sensor
LPF sensor (genuine)
Fuel control unit (genuine)
I have been sharing with the guys at JHM, they asked for the full VCDS codes, and for logging, but we have been unable to find the source of the problem.
Over the course of attempting to solve these issues the car became increasingly more drivable, almost back to the beautifully smooth car we originally purchased, yet enhanced by JHM short shift and stage 1.
The problem was that we could never get the codes to go away, and when reading measuring block 106, the new LPFP duty cycle at idle has been slowly getting higher, till today it finally gave out altogether - poof!
At installation 54% (the upper end of acceptable)
Two or three weeks later, 67%
Another week later, 76%
Earlier this weekend, 83%
Today, non functioning.
I watched this happen wondering whether the numbers I was seeing were real, and how the duty cycle was calculated. I guess I got my answer to the first query, but still wonder about the second.
I have done things like check the voltages and ground at the sensors. I blew the fuel line through with compressed air while the ends were disconnected.
The high pressure rail is all new because I changed the intake manifold.
Summary - car has been running better and better as we added new parts (some made no difference), yet through the codes and measuring block 106 we watched the LPFPumps demise.
Note - if I hadn’t had the misfortune to experience this I’m not sure I would have believed it!
Exactly what I’m going to do now I do not know… suggestions would be very greatly appreciated.
