So yesterday when I took out my Noggy I noticed a weird noise coming from the passenger vent! It sound almost like a spooling sound and when I press on the gas peddle the sound gets louder!(WTF) So I go to turn the head lights off and the noise goes away a little bit. I’m think it might be 2 things! Fuel Pump or Alternator?? What do u guys think?
Guys do u think it’s coming from the speakers??
Could be the speakers. Do you have an aftermarket radio or nav unit installed? On my old B6 A4 I was getting interference that increased with RPM. I could never figure out what was causing it.
Try putting on some blank audio or maybe put it to aux with no input and turn up the volume. See if the noise gets more noticeable.
I get a similar noise when I make calls over the bt.
Everything is factory in my car. This noise is not permanent it stays for like 30min and then it goes away…
probably coming from the speakers due to a bad ground cable.
When you get a feedback like whine that increases in noise with RPM’s it’s usually a bad ground like Meistah said.
Where would be the best place to start looking for a bad ground? The speaker making the noise?
The amp
