Just curious if anyone on the forum is in the West Michigan area? I’m in Holland and recently picked up a Ross-Tech cable and want to do a little coding. The SAI pump is shot and throwing a CEL. I want to code it out and looking for someone to show me the ropes on Audi coding. I’ll gladly supply the beer! ;D
Holland is a bit far from myself but if I can help I’d be happy to. The only down side is that you can’t turn off the Sai with a VAG con. You would need to code it out in the ecu. But countvohn is local to metro Detroit and might be able to help you with that.
Welcome to the forum
