What are the real differences between the S8 and the S6
I know a few people have ask me the real difference between the S6 V10 and S8 V10 and to be honest I don't think there is a real difference. When you look at each car and each difference the only real differences come in a few parts. I'll post the differences when I can load more pictures. The only noticeable difference. The S8 has better air box flow and the S8 has a better smoother exhaust system in the cat back section. Other then those few things the only real mechanical difference is in the total gear ratio. Before we get too far into the conversation here is the tail of the tape between the two cars. They are much closer than you would think.
              V10 S8 ---- V10 S6
    Hp           450   ---   435
    Tq           398  ----   398
  Comp raito 12.5:1 -  12.5:
      Bore      3.33in --- 3.33in
     Stroke    3.65in –- 3.65in
     CID      318 CU – 318CU  = 5.2L
Block aluminum – aluminum / Heads aluminum – aluminum / Crankshaft Forged steel
12 5:1 compression. Firing order 1-6-5-10-2-7-3-8-4-9
Transmission gear raito.
         S8   ------  S6
1st 4.171:1 - 4.171:1
2nd 2.340:1 – 2.340:1
3rd 1.521:1 – 1.521:1
4th 1.143:1 – 1.143:1
5th .867:1 — .867:1
6th .691:1 — .691:1
FD 4.055:1 – 3.801:1
     Total weight
   S8 -------- S6
4586lbs — 4486lbs
CAPACITIES of the S8 and S6
Engine oil 10.6 Quarts Both.
Fuel tank S8 – S6
23.8 – 21.1
Over all length S8 ---- S6
16.5’ 16’
 Width   S8 ----- S6
            6.25’ --  6.5’
Height S8 — S6
4.675’ — 4.75’
Breaks Front S8 — S6
385 MM — 385 mm or 15.2”
Rear
335 MM – 330 MM or 13”
Both cars are limited to 155mph
Both share the same turning radius
http://audirevolution.net/addons/albums/images/433331063.jpeg
http://audirevolution.net/addons/albums/images/702456259.jpg
http://audirevolution.net/addons/albums/images/25270200.jpg
Audi of America distributed to dealers and outlets. It includes over all width with Mirrors.
http://audirevolution.net/addons/albums/images/447810987.jpg
The front breaks are the same and that’s a big deal. I felt my JHM lightweight rotors were well worth the weight savings and helped the car gain a more nimble nature.
I’ll post more later. This was just a quick conversation starter.
