This post will have both the S4 and RS4 motors in here for you to look at.
While both The RS4 and S4 motors share the same fill frame aluminum composite motors the motor structure, the motors are not the same.
The RS4 seems to be the Next generation of aluminum motor. The web walls are stronger and thicker then the S4. Components like the pistons and rods are different. Some say this leads to no cylinder wall score issues. I tend to lean towards that as well. The RS4 takes what the S4 motor did great and beefs it up a bit.
The good thing is that when people start to build the S4 motors, if they know and can identify the changes added to strengthen the RS4 motors these little additions (those that can be implemented) will really help.
Lets start with a quick picture of all 4 generations of the Audi aluminum motors.
On the top left, Gen 1 thats the 3.0 motors for the A4 and A6 motors. That motor is very strong and they have metal selves to help keep the strength up.
Top Right, Gen 4 the RS4 motor. The latest in the list of evolved Audi motors.
Bottom left. Gen 3 the S4 motors. This is the first attempt to use the special hone and not a wall coating to be able to eliminate the Gen 1 metal sleeve and the Gen 2 wall coating.
Bottom right, Gen 2 V8. This motor came in a few cars. It was the first aluminum Audi motor to not have the sleeves. Some reports came back saying that there were a few motors that started with the metal sleeves and then Audi used the Wall coating to strengthen the walls. A common practice in the Porsche aluminum motor series.
http://audirevolution.net/addons/albums/images/915909378.jpg
When we look closer On the S4 and Rs4 we will see that they went to a two piece, main girdle design. This adds a ton of strength to the motor as a unit.
http://audirevolution.net/addons/albums/images/984997505.jpg
If you have never seen the full face of the S4 motor you will see its ALL aluminum.
http://audirevolution.net/addons/albums/images/290097915.jpg
While Ive never been a big fan of the Cut away motor pictures. Looking at the S4 and the RS4 together like this really puts the jump from one motor to another in perspective.
S4
http://audirevolution.net/addons/albums/images/87305023.jpg
RS4
http://audirevolution.net/addons/albums/images/660096015.jpg
The good thing, at this point in time is that the Aluminum Audi motors have held there ground for quite sometime. The neigh Sayers of the past have been proven wrong when it comes to the strength of the aluminum motors, or at least the blocks.
