What is the actual performance on the V10 S6 / S8
Reserve 2
Actual real-world performance results.
Before we get too far into the performance side of what all the mods now available for the V10 can do, it’s best we cover what the actual stock abilities of the V10 S6 and S8 are.
When you look at the S6 and the S8 on paper the S8 make lots more power and should be faster. That only seems to be slightly accurate. For the differences between the S6 and S8 check here.
http://audirevolution.net/forum/index.php?topic=3960.0
As for the actual performance on a stock V10 S6 or S8. The range seems to be between 14.4-13.9 if you have a carbon clean a non-broken intake manifold great running car you’re looking at being able to run in the range of 13.9-13.7 in the MPH range of 103.
Some tracks and some conditions might help get a car to just dip a little lower or slightly higher in the ET but the MPH seems to all be in the 102 103 range.
When you read publications they say the S6 and S8 are much quicker. So far we have not had anything to back that up. Real world results show most cars are in the 14-second range. Several AR members have track tested their S6 and S8 cars and all came in the 14-second range.
A test done by Edmonds resulted in a 14-second run as well.
https://m.youtube.com/watch?v=tq_JiCFADjc
As mentioned later in this thread. My JHM tuned S8 crushes all these times by a large amount. So, there’s hope yet for the 5.2 V10
Below is open discussion on what we would all consider the actual stock performance range to be
