What would make my car not
Engage shifts at WOT!?
So when i try shift through the gears at WOT, it wont go unless i try few times to find the perfect spot or timing, if i make sense!
If it’s more at WOT that’s the synchronizes or synchros… they help in the gear shifting. The RS4 is known to have weak 3rd gear synchros. Next time your at jhm have them check the transmission out or check the fluid to see if it’s got material in it I saw in some of your videos you blip the throttle before down shifting. That can be hard on synchros in some cases
You also might just be a sloppy shifter.
No sloppy shifter man! The way i take care of my car is the same way i shift, nice and easy!
Justincredilble, yea i did blip few times but I usually dont do at all, only when i was showing off the exhaust:).
So yea most of the times will be from 2nd to 3th gear, but i got bad ones few times from 1st to 2nd!
Just thought I would add in the blip as reference. Euroswagr good call on the shifter too that could have been another issue.
Yes the 2-3 synchros are weak and go out over time. You have a supercharger so if your really on it you have to be right on with the 1-2 shift. If i remember the 1-2 synchros are bigger so they can take more of a beating
