What's inside a C6 S6 Intake Manfold? Find out inside!
Sorry for the cheesy title.
After removing my manifold yesterday, and discovering it was faulty, I decided to take it apart to see what was up.
So, before we go through how to take apart your intake manifold, let’s make sure we know what each of the components are, and what it is they’re doing.
HOW THE MANIFOLD WORKS
From the service training document, we have a good overview of the design-
There are two flap systems;
  1. Intake Manifold Flaps - used to induce tumbling of the air at low rpm by in order to increase torque.
  2. Change-Over Flaps - Used to switch between a long-path and short-path
http://i57.tinypic.com/2qxxbth.jpg
Change-Over Flaps (click to enlarge)
http://i61.tinypic.com/m81ob7.jpg
Identifying them on the manifold:
http://i59.tinypic.com/azgwv7.jpg
The two sensors are used to determine in what position the flaps are - and if they are not operating correctly, you will get a CEL. It doesn’t seem as though the Change-Over Flaps have the same.
Now, to business-
TAKING THE MANIFOLD APART
If you read my thread here http://audirevolution.net/forum/index.php?topic=3221.0, you will see how to remove your manifold.
Now that it’s off, here’s how you can take it apart.
Be aware, before you start, that to put it back together, you are going to need to do a LOT of rebuilding fine gaskets.
First, remove the two actuators and the sensors. The sensors use Torx T20 screws, and the actuators use Torx T30. To remove the Intake runner ‘tumbler’ flaps actuator, you will also need to remove a circlip at the end of each arm. Use two flat screwdrivers to push on each end of the ‘C’ and it will come off (most likely flying off, so put a rag or something under to catch it)
The manifold is in two main sections, top and bottom.
From the top, there are 5 Torx T30 screws along each long side.
From the bottom, there are 5 Torx T30 screws along each long side, set in from the edge. There are 4 Torx T30 screws on the intake ‘mouth,’ and 2 Torx T30 screws at the ‘front’ of the manfold, one of which is hidden under the Intake runner ‘tumbler’ flaps actuator.
Once you have removed all the screws, you will need to break the sealing gasket which is still holding the top and bottom together. The joining face of the top and bottom half have a ‘ridge’ which means you won’t be able to wedge something all the way through until you have already broken the seal. So don’t try and force anything straight through.
http://i57.tinypic.com/fmlylj.jpg
Start to break the seal by starting at a corner at the front of the manifold, where one of the ‘top’ screws was previously seated. Wedge a blade partway into the gap, and gently tap it with a hammer to open the gap. Work the gap open until you can wedge something slightly larger in (like a (smooth) flat head screwdriver). Leave that wedge in place, and now go to the next ‘top screw hole’ (which direction you go doesn’t matter) and do the same. Three screwdrivers/wedges should be sufficient - when you reach the fourth point, remove the first wedge and place in the new position, etc.
Continue this way, using progressively larger and larger wedges, and eventually the manifold will come apart.
WHAT WAS INSIDE MY FAILED MANFOLD AND WHAT WE CAN LEARN FROM IT
Here’s what you first see:
http://i58.tinypic.com/2rxgtnk.jpg
One the left, the top half, on the right, the bottom half.
Each of the ridges in the centre part of the bottom half have gasket material on them to keep the runners separate, as well as the square shaped borders of each port. These gaskets will pretty much be destroyed when you take it apart, so you’ll have to be prepared to use a liquid gasket to remake these if you want to use the manifold again.
Now, let’s have a peek down the tunnel and see what the flaps look like. Note that you should be able to see this same view by just removing the ‘air distribution housing’ (the thing the two throttle bodies sit on), and putting a camera down there.
http://i60.tinypic.com/141r2te.jpg
Oh. That’s not good. Aside from the bits that already fell out and into my intake runners, looks like there’s more to come.
However, the Intake Manifold Flaps (tumblers), look to have full movement with no jamming or much resistance (one was slightly gummy).
Back to the changeover flaps-
http://i57.tinypic.com/w6s2us.jpg
The issue of manifold destruction is already well noted, in other models, if not on the C6 S6.
In my humble, non-engineer’s opinion, this really seems like a poor design. My car has about 150,000 km, but I can’t be sure how long it’s been like this. I can’t recall a time when it had significantly more power than it did before I took the manifold off, and I picked the car up at 70,000km. That’s about all I can say for longevity. Apparently the new manifold has an improved design, but I’m not willing to crack open my new manifold to find out what that entails. If anyone has this info, please share.
Upon a closer inspection, each of these “link holders” which provide a housing in which the flaps rotate, are ‘formed’ into the manifold. They are not held in place with screws, but rather there are three plastic stubs which go through three holes in the metal - then the ends of the stubs are melted and pressed so they ‘mushroom’ out and are retained. I hope that makes sense. Because these stubs back into the manifold runner, you can understand why they didn’t use screws, which would interrupt the air flow.
http://i62.tinypic.com/110ezuo.jpg
It seems as though this is the first point of failure (again, not an engineer), and all other failures follow from this. The plastic is worn away as the supports are lost because the geometry changes. Then the flaps must get jammed, and the initial link snaps.
So, I hope you can appreciate that unless you’re some sort of CAD wizard with a 3d printer, there’s pretty much no hope to save your manifold if it is in this condition. It is a great shame that Audi don’t offer the parts to replace the changeover flaps (so far as I have seen - I have searched through ETKA as well). As a new manifold is the best part of $2000 - it seems like quite a lot to spend for some plastic parts. The rest of the manifold just goes to waste - but maybe this one can be used for testing/development!
-P
