Whats the latest IM version
I’ve been working on my (new to me) 2007 S8, it was noted on the Audi service records that the IM has failed on my car, but had not been replaced by Audi as the previous owner had gone and had the repair at an independent shop.
Below is the part fitted to me car part # 07L.133.185.M, with what looks like a Nov 16 build date.
http://audirevolution.net/addons/albums/images/728113041.jpg
Sorry for the side on photo, for some reason it auto rotates it.
Can anyone confirm if this is the latest greatest version?, anyone know if this version still have issues or not?
Cheers
Ross
if you have access to a snake cam or dentist mirror you can check inside and see if the flaps have a blue surround vs a orange surround.
blue is the updated flaps.
Exactly. snap a picture of the inside…
But given the date you have what would be the latest. Now… keep in mind there is another update coming from Audi in oct of this year but if you take good care and clean and lube your current intake I don’t think you will have any issues.
Thanks Justin, what is the recommended cleaning and lubrication procedure?
I recently ordered a new one as well from JHM; apparently Audi is revising them again and won’t be shipping until next month at the earliest. :frowning:
Justin posted on one of my queries, cleaning he said was simple, spray it liberally with simple green let soak and then rinse!
There are a few floating around the US of apparently, im trying to locate one…but as you know the re-release is causing delays.
any idea what Audi is revising again?
neil_cb125t the NEWEST intake manifold revision won’t be out till sometime mid OCT or eairly NOV. There are NONE of the soon to be OCT intakes available as of yet. The only intakes that are out there are going to be the older NOV intakes with the current system not the updated components.
So don’t be fooled. This has happened in the past with OEM venders. Some venders have older part numbers and just want to offload stock. So don’t be fooled. If you want to have a safe bet just order from JHM they will for sure be getting the newest versions as per there site and 99% of the time JHM has the cheapest prices.
After the newest OCT versions come out you might see venders with the older intake sell them for cheaper just to get rid of them.
As neil_cb125t posted. I have been using simple green. I spray down the inside very well you have to remove the top Y section to show the open section.
I spray down the intake making sure to get the back section where the linkage gets bound up and make sure to really get the flap mounts really good. From there don’t spray water in the intake. I use a template I made with an air hose extension on it that I bolt to where the Y pipe would go and I intraduce air to blow out the access simple green. I cover one entire side of the intake ports to create pressure to force out the simple green out the other side and then repeat with the other side.
Obviously you guys won’t have a template that you can bolt down unless you want to make one so you can just use a towel and a air line you just need to make sure you have lots of pressure.
I found that this works incredibly well. Simple green won’t dry out the intake and it leaves behind no adverse residue. It helps break down grease and cought dirt if there is any. You might want to rotate the intake manifold a few times after you spray in the simple green.
I will say this. While I always see a nice collection of dirt and grime come out when I clean the inside. We need to remember that these intakes even the original ones didni’t brake until they had like 80k on them and that’s with no carbon clean and obviously no maintenance all together. So don’t get too hung up on spending all day cleaning the intake.
http://audirevolution.net/addons/albums/images/370617913.jpg
Latest MFG date
If they woul have changed the spec, wouldn’t they have changed the part # suffix?
Most of the time yes. Has audi in the past made changes and not changed the suffix yes.
