Have any of you run wheel spacers with your stock wheels for an extended period of time? If so, which ones and what brand? From what I found online, MTM is the only one that makes exact fit spacers, but seems they only do 10mm… soooo 10mm on front and back? Please advise. Saw an S6 with S7 wheels and it looked so sexy… crazy how much of a difference a few mm can make.
19x9ET40 put the wheels not quite flush - I can take some pics if you like. What’s the offset of the wheels you’re on now?
Don’t know. They are stock C6 S6 wheels with stock offset. 265s all around. I just googled it and it says they have a 52mm offset
et32 based on this other site I found…
http://www.wheel-size.com/ says 19x9et52 as well… Anyone else know for sure?
Also, I thought higher offset meant further away from the hub center, but that’s not correct is it?
This is correct, 19X9, ET52. Higher positive numbers = wheels further in.
