Want to get your opinions on an issue I’ve been having. It started last weekend when I couldn’t get my S4 to go into any of the gears. The car was running at the time (cold start) and seemed completely normal expect for the gear issue. Basically, each time I tried to put into any gear it would fight against me and make a light grinding noise. It lasted only a few minutes and after restarting the car I was able to get it into all the gears. It drove fine afterwards.
Now a couple of days later, I’m getting a really quiet whining sound when I engage the clutch pedal. Unfortunately, It’s probably to quiet to record on a video thanks to my exhaust. But it almost sounds like when you turn the wheel all the way to one side and the power steering pump starts to struggle. It happens every time I engage the clutch pedal but the car still drives 100% normal.
After some research, I’m thinking it might be one of the following:
-throw out bearing
-slave cylinder failing
-or my clutch is going needs to be replaced
My car is a 2005.5 S4 with 69k miles on it. It’s never been tracked and only launched a couple of times. The brake/clutch fluid was recently changed with ATE Super Blue. I’ve never had any type of clutch slippage that I’ve noticed.
I really don’t have a lot of knowledge about transmissions. I’m more of a shade tree mechanic that does my own engine/brake work so any input is greatly appreciated. I’m thinking the slave cylinder is the only issue that I could tackle on my own since the throw out bearing or clutch would require a transmission pull, correct?
