Who knows some technical suspension stuff to help me out here...
So I’m in the market for new suspension because I’d like to stance my car. As most anyone who reads my thread know that I’m avid Genuine Audi parts only if its not a JHM mod. With that said I would love to replace my 02 sport suspension but with a price tag from GAP of 2115.00 not including shipping. or from my local dealer no shipping but price matched with tax added. I was thinking I maybe have some better options with a set of coilovers. I am about 130k and my car is a bit bouncy and doesn’t stick to the road like it used to when I got it at 90k. So I’d love to feel a new set of 02 sports but would they really be any better than any of these options. I never track, launch or abuse my car, rarely i drive it with a bit of enthusiast and stil want it to perform properly and better than a new genuine 02 sport would, which my only issue is could be maybe a half inch lower at most. Also I dont want to drop it too much because I dont want to have to buy adjustable control arms. Which is another bonus of having stock suspension no shops can ever give me shift if I were to ever have issues with tire wear because stock suspension will not void warranty. and 02 is almost low enough and I think still looks really good.
Also I know this may sound weird but I’ll likely see if I can paint or powder coat any colors that don’t match my car like purple and yellow. So it looks custom and clean. So heres the info and prices i have on these setups from AZ and quick google for prices…
Bilstein PSS9 A4 (~$1995 from JHM): Linear rate springs. Front is 515# with 145# helper spring, Rear is 515#. Dampening is adjustable on car. Adjuster knob adjusts compression & rebound at the same time. Height adjustable on car, spring adjuster is located at the top of the spring.
http://i1190.photobucket.com/albums/z457/A4QuattroV6/dfe12dcd-6202-44a2-9ff2-e98e49becfce_zpseb048940.jpg
Vogtland (~$989): Progressive front spring and linear rate rear spring. Front has a working range of 500# (475#-525#) rear is 550#. These numbers are from Vogtland USA. Height adjustable on car, dampening is preset by factory (otherwise non-adjustable)
http://i1190.photobucket.com/albums/z457/A4QuattroV6/VotlandsuspensionJHM_zpsd9aaebd7.jpg
ARE THESE THE GT1’s???
GT1 from ACHTUNING if they are different than JHM carries are 899$,
http://i1190.photobucket.com/albums/z457/A4QuattroV6/a9c0b3eb-3271-4524-bb9c-d12f955f651c_zps05c308fe.jpg
STaSIS Street Sports (~$1000): Progressive Springs Front & Rear. Front have a working rate of 450# and the rears having a working rate of 440. Height adjustable on car, height adjuster is located at the bottom of the spring. Rebound adjustable only when shock is off the car. STaSIS has preset the rebound to work with spring rate. 1” CNC’d spacer for rear spring ride height is available for $75
http://i1190.photobucket.com/albums/z457/A4QuattroV6/a1013295-9aec-4bef-90e5-a6948b2b5bfb_zps8964f28a.jpg
KW V1 (4cyl-Q) – (~$1200) : Linear Front Spring and rear spring. Front is 580#, Rear is 470#. Height adjustable on car. Damping is NON-Adjustable
[b]KW V1 (4cyl-FWD) – (~$1200) : Linear Front Spring and rear spring. Front is 580#, Rear is 380#. Height adjustable on car. Damping is NON-Adjustable
KW V2 (4cyl-Q) – (~$1500): Linear Front Spring and rear spring. Front is 580#, Rear is 470#. Height adjustable on car. Rebound Adjustable only when uninstalled.
KW V2 (4cyl-FWD) – (~$1500): Linear Front Spring and rear spring. Front is 580#, Rear is 380#. Height adjustable on car. Rebound Adjustable only when uninstalled.
KW V3 (4cyl-Q) – (~$1750): Linear Front Spring and rear spring. Front is 580#, Rear is 470#. Height adjustable on car. Rebound Adjustable & compression adjustable on car with modification to car. Otherwise Rebound adjustable only when uninstalled, compression adjustable while installed.
KW V3 (4cyl-FWD) – (~$1750): Linear Front Spring and rear spring. Front is 580#, Rear is 380#. Height adjustable on car. Rebound Adjustable & compression adjustable on car with modification to car. Otherwise Rebound adjustable only when uninstalled, compression adjustable while installed.[/b]
V3
http://i1190.photobucket.com/albums/z457/A4QuattroV6/k3_zps4527be28.gif
