http://i15.photobucket.com/albums/a375/Irani/D1-Pic.jpg
Introducing the most advanced performance Racing Voltage Engine Power Chip straight from Japan:
IMAGINE the new 2012 D1 Spec Motor Racing Sports Engine Power Volt Chip in your ride!
This is our highest performing chip. If you are looking for maximum performance, this is it.
Used mostly in the Japanese Drifting and Street Race scene, this product is now available exclusively through select auto parts dealers in the United States. Only an authorized dealer can guarantee the performance.
When a drag racer or street racer wants maximum performance, they shut off all electronic parts, including even the lights in a pure drag race. This is done to maximize all available voltage and make sure that the most important parts, the engine and drivetrain have as much available power as possible to generate ignition spark and engine timing. D1 Spec is the highest performing unit of voltage units possible. Beating out even the Bellon line by over 30% in capacity.
http://i15.photobucket.com/albums/a375/Irani/D1Tech-1.jpg
The D1 is designed to further improve both your electrical system and engine load due to the alternator running. Once installed on your vehicles battery and grounded into your chassis, the D1 will store all idle electrical energy and release it based on engine load as necessary. When your vehicle has multiple components like the headlights, radio, navigation, climate control or other functions turned on, your vehicle is under a much higher electrical stress load than when they are all off. This chip will now allow zero lag or bog occuring from loss or low voltage levels and will make sure your alternator will be operational at much lower levels enabling for more engine power to be used for actual driving and not electricity.
You will notice an immediate improvement in idling, start-up, throttle response under load, brighter headlights, better sound response in a much more efficient and powerful vehicle able to start with NO problems on the Coldest or Hottest days nature can throw at us. Also if you have ANY static electricty interference in your vehicle producing “electric noise” during acceleration in your vehicle, the D1 racing unit has enough capacity to get your cabin down to competition level sound quietness.
lolz/
