Looking at some Vossen cv-5s. They are 20x10.5 et 42. They were on a 2015 a6. My car is 08 s6.
Will these wheels fit or are they too wide?
Are the center bore’s the same?
Probably run 285 or 295’s
Thanks guys
There was an owner if I remember correctly that had 2012 A6 rims on his S6. Not sure if 2015 is much different.
What’s your suspension set up? I had 20x10et35 Rotiform SPFs with 255/35r20 and they were huge. They did fit tho. The wheel spokes are similar what you have in terms of clearance.
https://i.imgur.com/1yc8vxi.jpg
Here’s the wheels on the stock S6 suspension (looks like a 4x4)
https://i.imgur.com/Hb7xtop.jpg
(bottom pic is stock suspension)
https://i.imgur.com/iqH3S6s.jpg
I think 275s are going to be tight enough to fit, but some guys don’t like stretch. That would be a mild stretch.
You’ll have to roll the front fenders to avoid gouging the tire.
I’m on air suspension, so that changes things. The biggest thing you’ll have to account for are the massive front calipers. My current wheel is 19x10et42 and I run 20mm spacers to clear the brake, different wheel, but just an advisement.
Thanks guys. Suspension is stock. Sorry didn’t mention that earlier. Maybe H&R springs later.
