Thought we had a list going on this site but I couldn’t find it. Search fail on my part? If I f’d up we can purge this one on to the tail end of the existing one I guess.
Short and to the point - some of these may not be possible but I’ll throw them out there for discussion. Some may not make sense either - I’m no expert, just getting the ideas out there for discussion (Sorry if there are repeats from the other thread on my list)
Larger throttle body
Throttle body spacer
Cooler thermostat (btw, is it safe to add water wetter to our coolant?)
Heat shield for air box components. (In addition to using heat reflective tape etc). Something that keeps the passenger side exhaust heat away from the components.
Water/meth kit tuned for N/A motors, introduced via the I/M at each cylinder - clinging to hope of my idea that adding a fuel system cleaner to the mix [Techron for example] would help mitigate the cb buildup. It’s always nice to remove some heat if possible as well.
For those of us who may go F/I, does it make sense to use a thicker head gasket?
Cooler range spark plugs?
Any other lw parts left that make sense? LW Drive shaft?
