This took me a lot of time and risk as I see no one had done this retrofit yet. For starters C6 RS6 Master is the same as the C6S6. Calipers purchased from v8a6 (thank you v8a6!)… I am going to say that the “wobbly” caliper is not really an issue, but how these are designed, persay. Give yours a tug next time your doing a brake job and id imagine youll see the same. But I dont like it!
Calipers were $800 - C6 RS6 / C7 RS7 (similar to and same pad as Benz 63s, ZL1, Aston Martin, GT-R, CTS-V, etc)
Discs, bells, and hardware was $1240 shipped + $41 in Duties - AP Racing / Loba, 390x36
This was just a test fitment to confirm RS6 sizing is the same as the S6, still waiting on pads for the 63 AMG to come in today (soft hawk streets), and caliper fixings (spring, pins, etc), and new bracket bolts from the dealer to mount. Will most likely run the rubber lines for now until I source ss front lines. Maybe source ss lines from the rs7.
My stock calipers are fine, running them as we speak, they are just “old” 120K and needed the guide pin bushings replaced, seals are fine. I will be selling these on az in a few weeks for someone who wants a bbk upgrade to their c6 (non 3.0t) or their d3.
I am just not a fan of floating calipers and find it hard to “trust them” under abuse, I just want to make sure I have done all I can do to make sure I stop every time safely. Also the monoblock does have some curb appeal
I wanted some weight savings over the stock discs as well being they are ~38 lbs!! lol
Before I install anything I plan to weigh stock vs this setup and report back. From calculations the 390 mm rotors are 29Kg (64LBS) VS stock S6 385s which are 76 lbs, so savings of 6 lbs per side. Still TBD…
“I’d seriously immediately give up on the car considering how fatigued I am from fixing all the other issues…”
- LOL, how I felt about my boost leak machine stg3 allroad. Took me 2 years to get all the leaks to stop. I am already seeing leaks around my chain tensions on this 10 banger so I plan to replace those seals / o-rings soon, I believe my thermostat is bad to, so I think it is just beginning for me.
Again, we have audis for a reason
