These things are horrible… I cannot believe Audi gets away with using such an inferior part on such an expensive engine. End rant.
This is actually a pretty simple job, but given the amount of space allotted it’s challenging in the sense that you’re basically taking out one screw completely blind.
There is a bracket I believe that goes from the intake to the oil separator that needs to be removed, both are t30 torx screws, if I recall correctly.
From there disconnect the breather hose from the side of the oil separator as well as the driver’s side valve cover. Just be careful not to damage it as overtime they get brittle and I think they are upwards of $200 to replace them.
From there you will need to use a t30 bit to get the top and bottom screws off of the oil separator. I prefer to use something like this in order to get them started. Once loosened it’s easier to just do them by hand. Be careful not to drop the bottom one! I wedge an old rag in between the firewall and the engine in order to (hopefully) catch it in the event that it falls.
Lastly there is the oil return line from the bottom of the separator that leads back to the top of the block. That will need to be removed from the old one and put on to the new one. Might as well use a new hose clamp while you’re at it.
Installing is essentially the reverse. Word of caution: do not overly force the new one in to the port! The oil separator adapter that links it to the lower intake manifold is only secured by ONE bolt and because it’s very soft it is easy to strip/break the mounting point and you will have to remove the entire intake in order to (hopefully) re-tap the fouled up screw hole. If you’re having trouble coaxing it in, use the smallest amount of silicone spray/sil-glyde to provide a little bit of lubrication. I say smallest amount possible because you really don’t want that getting sucked into a combustion chamber.
Hopefully this helps! Again, it’s a pretty straight forward job that just requires some patience and funky hand work in order to coax the bottom t30 screw out!
Keep us posted!
     murphenur:
 murphenur: justincredible:
 justincredible: Nebuchadnezzar:
 Nebuchadnezzar:
