Ok, so finally got around to scanning the car.
Looks like something going on with the O2 sensors and a list of misfires now. (I had a chuckle at the speed of which the second O2 sensor warning came at… oopsie)
Noticing that misfires are happening off idle and under load… I don’t get a flashing check engine light until I’m off the gas. Also noticed that they are at different times at different cylinders.
So to recap… carbon clean has been done, new fuel filter, IM spacers installed, JHM Tune, new plugs, new valve cover gaskets, new coils, new oil/air separator, new suction jet, checked all around intake with starting fluid/brake clean and finally did a smoke test for vacuum leaks. None found. Still have lots of vacuum under oil cap.
I’m stumped.
I plan to cut out the cats anyhow in the next few months, and now replace the O2 sensors. And will likely pull the injectors to get cleaned and upgrade the bolts from the JHM Kit. I don’t see anyone else saying anything, but when I torqued the intake down as described in sequence at 11ft lbs… some of the bolts stripped. So I’d like to put better cap screws in.
The battery had died from the car sitting so some of these codes are related to that.
Self-Diagnosis Log
Wednesday,20,September,2017,22:05:58:15433
Page 2
VIN: WAUGN74F87N168471 License Plate: CHRIS S6
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F1 910 552 A HW: 4F1 907 552
Component: 5.2L JHM/V1 OCT9 ª0040
Revision: 59H14— Serial number:
Coding: 01050009190F0160
Shop #: WSC 02335 758 00200
VCID: 224BD8C3FDF3B856BC-8076
7 Faults Found:
000086 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
P0056 - 004 - Malfunction / Open Circuit - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 152151 km
Time Indication: 0
Date: 2017.05.22
Time: 17:44:01
Freeze Frame:
RPM: 635 /min
Load: 18.8 %
Speed: 0.0 km/h
Temperature: 85.0°C
Temperature: 39.0°C
Absolute Pres.: 980.0 mbar
Voltage: 14.351 V
008756 - Oxygen (Lambda) Sensor B2 S1
P2234 - 004 - Signal Shorted to Heater Circuit - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 157394 km
Time Indication: 0
Date: 2017.07.21
Time: 17:18:46
Freeze Frame:
RPM: 5131 /min
Load: 91.3 %
Speed: 232.0 km/h
Temperature: 96.0°C
Temperature: 30.0°C
Absolute Pres.: 970.0 mbar
Voltage: 13.462 V
VCDS
Self-Diagnosis Log
Page 3
053248 - No Communication with Comfort System Control Module (J393)
U1000 - 002 - - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 18.0°C
Temperature: 20.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
005464 - Throttle Actuator (G186)
P1558 - 002 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 18.0°C
Temperature: 20.0°C
Voltage: 10.033 V
009523 - Ignition Switch; Run/Start Position Circuit
P2533 - 002 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 158574 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 7.0°C
VCDS
Self-Diagnosis Log
Page 4
Temperature: 9.0°C
Voltage: 7.366 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 12
Reset counter: 255
Mileage: 158574 km
Time Indication: 0
Date: 2017.09.14
Time: 03:02:48
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 8.0°C
Temperature: 10.0°C
Voltage: 13.716 V
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 158576 km
Time Indication: 0
Date: 2017.09.18
Time: 06:15:29
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 84.0°C
Temperature: 27.0°C
Voltage: 12.319 V
Readiness: 0010 0001
VCDS
Self-Diagnosis Log
Page 5
Part No SW: 4F2 910 156 M HW: 09E 927 156 C
Component: AG6 09E 5,2 FSI USA 0050
Revision: --H01— Serial number: 0107159
Coding: 0000002
Shop #: WSC 02325 758 00200
VCID: 2F6D21F7BE21053E23-807A
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Coding: 0020920
VCID: 3169278FA81513CE35-8064
1 Fault Found:
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 4
Reset counter: 49
Mileage: 158574 km
Time Indication: 0
Date: 2017.09.14
Time: 03:07:18
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4282
Hex Value: 0x0024
Hex Value: 0x01A7
Hex Value: 0x00FF
VCDS
Self-Diagnosis Log
Page 9
10 Faults Found:
P0300 - 001 - - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 10
Reset counter: 255
Mileage: 152151 km
Time Indication: 0
Date: 2017.05.23
Time: 12:47:48
Freeze Frame:
RPM: 1117 /min
Load: 38.4 %
Speed: 0.0 km/h
Temperature: 12.0°C
Temperature: 15.0°C
Voltage: 13.970 V
000784 - Cylinder 10
P0310 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 9
Reset counter: 255
Mileage: 152151 km
Time Indication: 0
Date: 2017.05.23
Time: 12:47:48
Freeze Frame:
RPM: 1117 /min
Load: 38.4 %
Speed: 0.0 km/h
Temperature: 12.0°C
Temperature: 15.0°C
Voltage: 13.970 V
000777 - Cylinder 9
VCDS
Self-Diagnosis Log
Page 10
P0309 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 152151 km
Time Indication: 0
Date: 2017.05.23
Time: 12:47:48
Freeze Frame:
RPM: 1117 /min
Load: 38.4 %
Speed: 0.0 km/h
Temperature: 12.0°C
Temperature: 15.0°C
Voltage: 13.970 V
000771 - Cylinder 3
P0303 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Mileage: 152385 km
Time Indication: 0
Date: 2017.05.25
Time: 09:05:06
Freeze Frame:
RPM: 2233 /min
Load: 60.8 %
Speed: 28.0 km/h
Temperature: 27.0°C
Temperature: 18.0°C
Voltage: 13.970 V
000776 - Cylinder 8
P0308 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 153567 km
Time Indication: 0
Date: 2017.06.16
Time: 09:48:22
VCDS
Self-Diagnosis Log
Page 11
Freeze Frame:
RPM: 3801 /min
Load: 41.2 %
Speed: 28.0 km/h
Temperature: 27.0°C
Temperature: 18.0°C
Voltage: 13.843 V
000772 - Cylinder 4
P0304 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 157010 km
Time Indication: 0
Date: 2017.07.15
Time: 12:07:26
Freeze Frame:
RPM: 1171 /min
Load: 36.8 %
Speed: 0.0 km/h
Temperature: 26.0°C
Temperature: 28.0°C
Absolute Pres.: 990.0 mbar
Voltage: 12.827 V
000769 - Cylinder 1
P0301 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 158570 km
Time Indication: 0
Date: 2017.08.18
Time: 12:02:29
Freeze Frame:
RPM: 1140 /min
Load: 51.4 %
Speed: 0.0 km/h
Temperature: 19.0°C
Temperature: 23.0°C
Voltage: 13.335 V
VCDS
Self-Diagnosis Log
Page 12
000775 - Cylinder 7
P0307 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 158570 km
Time Indication: 0
Date: 2017.08.18
Time: 12:03:09
Freeze Frame:
RPM: 812 /min
Load: 39.6 %
Speed: 0.0 km/h
Temperature: 24.0°C
Temperature: 24.0°C
Voltage: 13.462 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 18.0°C
Temperature: 20.0°C
Voltage: 0.000 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 12
Reset counter: 255
Mileage: 158574 km
Time Indication: 0
Date: 2017.09.14
Time: 03:02:48
VCDS
Self-Diagnosis Log
Page 13
