I forgot about this thread. No time slip but I hope to get there this summer. I need a set of 15" wheels and a bias ply tire for the car to not destroy the rear end. A while back I chose not to convert the car to a solid rear axle setup for multiple reasons. I wanted the car to still handle well, the exhaust pipes visible under the Cobra has been something that drew me to the car for a long time, and Ford intended on the car being a track car, not a 1/4" mile hustler. So, I completely built the IRS setup but they are still susceptible to wheel hop when using a radial tire at the dragstrip, which is what breaks axles, which are $400 each!
The car is a little different now.
-Ported blower, plenum, and throttle body
-True in-fender cold air intake
-Fore innovations 1200hp capable return style fuel system with 80lb injectors
-Tuned by Bob Kurgan on E85. 600whp and 570wtq at 18ish lbs.
-Built T56 rated for 1000hp. Centerforce 6 puck sprung clutch. Not as bad as you would think it might be, but certainly not what you would want to DD in.
-Mechman Billet Tech 240a alternator (factory design is a very weak point on the car and alt. failure usually means fuel starvation aka melted motor. heat cooks them, it sits 1" away from the headers)
-Bunch of other stuff done since then: engine bay beautified, paint correction, different gauges inside, yada yada you get the gist.
Upcoming plans: suspension stuff mainly. Everything about the factory ford suspension and steering makes the front end of the car so numb and hard to place. So I am doing upgraded control arms and aluminum/delrin bushings in place of a lot of the rubber parts. Also ditching the H&R springs that are on the car and putting cut stock springs on the car. CUT SPRINGS??? RICER!!! Nope, they are linear, which I know, cutting the spring does change the rate but not much for the amount I am going to cut to get the ride height I want. The H&R I have now are progressive and I really hate the feel. I am going to 18" Cobra wheels with Toyo R888 all around.
So as you can see I am trying to not build the typical 1/4" mile or roll racer Cobra that everyone else does. I am building everything on the car to be balanced, strong, and I am doing my best to not cut corners. Ultimately my goal is for the car to handle extremely well while also having a ton of power on tap. I like just taking the car out and driving it for a few hours. A lot of guys that build these cars build something that you’d hate to drive for a few hours because it was built to impress their friends with 10 second time slips.
For some reason I do not have any pictures of the new engine bay configuration so this is all you get, a quick picture I took before putting the car in storage
http://i183.photobucket.com/albums/x59/joec1992/20151012_142939_zpsr7v3q521.jpg
