So got my Coupe quattro yesterday, here are the details from the previous owner, a picture and some of my plans
http://i75.photobucket.com/albums/i293/beemercer/2013-03-07084303_zpsb94e1754.jpg
Modifications/Work Done
Motor
034 injector kit
TAP ecu ( also stock ecu )
Bag 'o snakes
Suspension
New rear control arm bushings
New Solid subframe bushings
Interior
034 short shifter
Exterior
B4 hood and rad support installed ( need to be painted )
Euro front and S2 rear bumpers ( need to be painted and installed )
RS2 healights with wiring connectors
S2 front bumper fogs and turn signals
Maintenance
Rear subframe was repainted
new seals on the diff and new oil
New rear abs sensors
New poly diff bushing
New Diff mounts
New rear swaybar links
New wheel bearings all around
New driveshaft support bearing
New handbrake cables
New rotors and pads
New engine and transmission mounts
New Alternator
New distributor
New Coil
New thermo switch
New ground wire
Plans
-S2 or other 5x112mm hubs
-SSR Comps that were formerly on my A6
-Install the billstein shocks and h&r springs that came with it
-Clean up/put interior together
-Paint the bumpers/lowers white so its one color
-034 Big MAF
-Rods/Pistons/Turbo?
-4.2?
-TDI?
