It’s been awhile since I spoke last of the judder I’m getting reason being i was trying to get some miles on the car to see if it would improve the judder.
For those who don’t know I had JHM LWFW fitted about 5 maybe 6 months ago my car was fine to begin with then after 2 weeks it was juddering a lot but only when i let off the brake with no throttle as soon as i touched the throttle it disapears, the judder was enough to make the engine rock and the exhaust to knock quite a bit I also noticed the front wheels would move back and fourth ?
After taking it to a transmission specialist we decided to replace the clutches and at the same time fitted the RS6 flex plate. The judder was better but still there only when letting off the brake pedal with no throttle ? The wheels moving however had stopped ?
Then very shortly after I had clutch 1 problems car was banging hard when at a stand still kicking me in the back and car would not move forward with my foot on the throttle then it would all of a sudden leap forward with no warning.
It turned out to be the clutch pressure seloniod on clutch 1. So i brought a DL501 Repair kit and had the full kit fitted which was good as I now had the Gen 3 kit installed. Now i thought that maybe this was the underlying issue and would solve my juddering it did not
After talking to @Ape_Factory i tried doing a clutch adaptation via VCDS it completed successfully but it took a long time to complete, I’ve done the adaptation before a few times but it never took this long before ? How ever it did work and finish correctly, the judder was better but still there enough to still make the exhaust knock and rattle and the engine to rock very slight ?
I have tried everything to resolve this issue to no effect and it is driving me crazy !!
I’ve noticed if I just touch the throttle as the clutch is clamping up it is better with hardly no judder. I’ve also noticed that from a stand still if I let off the brake with no throttle it will judder until the clutch clamps up fully and then the judder stops car will be still moving but with no throttle ?
I wonder if the clutch pressure seloniod was on its way out for sometime and has maybe not allowed the tcu tune to not flash properly ? I’m just throwing that out there as a possibility??
It seems its only when the clutch is engaging I get the judder it’s enough to make the engine rock slightly and that makes the exhaust knock/ rattle very slightly ? I’ve also noticed it does not do it when the car is cold and it gets worse as the car gets warmer ?
The judder has got better and better with everything i have done including the last adaptation but it is still there and spoils it for me as apart from this the car is running great gear changes are super smooth and it’s feeling very fast !
I have found someone else with the same issue on the other forum that has got the same problem down to it starting after having the LWFW fitted for 2 weeks from what he has said are problem are identical !
He is the only other person I know who has this issue, he has the JHM stage 2 tune and the LWFW fitted he also has 034 engine mounts which I don’t have. Unfortunately his been working a lot to do anything with his car.
I am out of ideas as to why my car is doing this, as many people have the LWFW and have no issue at all.
I’ve asked JHM V10 Tech Support to maybe let me re-flash just to see if this improves the judder or to try upping the clutch pressure slightly or to adjust the rpm to say 900rpm but only when the clutch is engaging ? But as of yet have had no response ??
I know @Ape_Factory is now a dealer for JHM so maybe if I ask nicely he could have a word with them about this problem and see if he can get an answer ? Please if you don’t mind buddy ?
