With the expansion of the knowledge base of the 3.0 I thought it would be good to collect all the information in one area.
So far it seems in the short time here that we have been talking about the 3.0 were finding new things out quickly.
So lets start with this and you guys can either take over or add to this list.
Audi 2002-2005 3.0
Motor.
Best I can tell the 3.0 has one major motor code. From 2002+ the 3.0 motor code XXX was the same for both the same for the A4 and A6. What small cosmetic or parts chances to the motors are unknown at this time.
2002-2005
Engine Code: ???
2005 motor code.
Engine Code: BGN
Transmission
The 2002-2003 6speed transmission was the same as the S4. It had a 01E transmission. Not sure on the clutch and flywheel.
The CTV was available only till 2004? Not sure on that one
The Automatic Tiptronic 5 speed transmission seems to be the same for each year
ECU.
2002
2002 TIP
ECU: 8e0 909 559 A
2003
2004
2004 TIP
ECU: 8e0 909 559 L
2005
2005 Man
ECU: 8E1 909 559 B
TCU: At this time Im going to make the assumption that all 2002-2005 Tip TCU boxes are the same part numbers
2002
TCU: 8e0 927 156 Q
2003
2004 8E0 927 156 Q
TCU: 8e0 927 156 Q CVT
At this time I don’t know what ECU will be compaitable with what year. The communications line seems to be the same much unlike the B6/7 S4 where in late 2005 the ECU communication lines were changed
This is just a rough start feel free to help add to this. I know I will as I get more
