Over the last 6 months my 07 S4 has developed an issue accelerating in the lower RPM’s. At first it was very intermittent but now it happens quite consistently. The car has 91k miles on it but I have done a ton of preventative maintenance and besides for this issue the car has a clean bill of health. I am most likely supercharging it by the end of the year but want to get this sorted out before I shell out the dough to JHM.
The issue is under medium acceleration from about 2k rpm to 3800 rpm sometimes the car sputters and falls flat on its face. It feels like it is misfiring or choking to a certain point then the power kicks in once in the higher RPM. You can compare it to driving for the first 30 seconds on a cold start before the motor smooths out. It is very jumpy and with catless exhaust it seems to almost backfire and pop when this is happening. If I’m accelerating lightly it is smooth all the way to redline. It is very noticeable when downshifting to second when say I’m rolling a stop sign then accelerating or downshifting to third to take a turn and then get back on the gas.
Once it gets passed 3800 or 4k rpm the car is a beast and feels completely normal. There is no CEL and I have scanned it probably 15 times with no codes. I have tried to do a throttle body alignment through vag-com but not sure if that worked correctly. After it was done the max value when the gas was mashed was 86% and the adaption step counter never changed, however it said the adaption was complete.
What should I look into next? MAF? Throttle body? Fueling?
