Ahhh, I was overthinking it, so the Picture Icon is really upload any file Icon. Got it.
I decided to remove the axles now. The rear main axle nuts were on pretty good and I still have to whack it a bit to separate it, but that is the last thing before positioning the platform jack under the engine. It is 50 cm wide X 80 cm long, so it is about 40 cm short (120 cm from front mount hole to rear trans hole) to cover from the front engine support to the rear transmission support, but it is plenty wide to cover the mount holes left to right.
I am about ready to yank the engine but I am still wrestling with how to support it. I want to replace the motor mounts and I don’t wan’t to interfere with them. The table and support layout in the Bentley, when I map it out, doesn’t match the driver side front hole for positioning the factory tool support. It seems to jive with the holes hidden by the subframe and the front hole on the passenger side. I have not mapped out the transmission mounts yet, but they seem to match looking at my drawing (though I can’t use the rear one - not sure what to do there yet).
I have determined (I think) that the dimensions on the table pictured in the Bentley as 12cm squares. At least that seems to match up to three of the four engine holes.
Is it possible that the Bentley is wrong? The WP assembly sits right where that support wants to be from the Bentley.
Here are the mounting points (all pictures are taken looking up at the engine from the ground):
Engine Front:
Engine Rear (currently hidden by subframe):
Trans Passenger:
Trans Driver:
Trans Rear:
No matter, what I think I am going to make my own VAG tools. I intend to take 4x4 or 6x6 blocks, drill a hole, use threaded rod, washers and nuts (2 nuts/1 washer for top and 2 nuts/ 1 washer for bottom. The hole will be deep enough to thread a bunch of rod into it. I will make sure the rod will fit the holes on the engine/transmission.
Using 2 nuts and 1 washer at the top and another set at the bottom, I think I can thread the bottom bolts enough that a few inches make their way into the block, then I can use the top nuts/washer set to support the engine, spinning them up to make contact. If there are any adjustments to be made for the holes that go directly into the engine or trans, I can make the same spin adjustment from the bottom. I will do another set for the rear engine support holes (that will be hidden by the subframe), just some block for the subframe and then make 2 more block/rods for the transmission. Or I can make a little frame, secure the blocks to the frame and make 3 sets for the transmission. The rear of the frame will hang over the edge of the platform jack supporting the rear most hole.
So a few questions:
- Has anyone seen the Bentley and confirm I am not crazy or seeing things?
- Are the holes I have ID’d the correct ones?
- What do you think about my home made engine support idea?
- Can I get away with 2 supports for the trans (I can get an engine hoist on it, or jam some lumber under it once it’s out) or should I build my frame deal?
I think I need to buy the rod/nuts/washers, but I will check around here first.
Again, any BTDT’s would be great. I don’t want to break this thing when I pull it.
Ed
