I’ve been cooking up some #westlogic I’d like to share with everyone. First up is front aero. The hood is a high pressure zone which limits the cooling efficiency of the heat exchangers, and forces warm air into the wheel wells which creates lift on the front axle. I’ve been noticing the hood vents on 2000-2008 Mercedes cars and I think they’d drop into the S4 hood nicely. I don’t want to replace the OEM hood because I think an Alibaba hood would blow off of my car at 130 MPH - I’m not even certain how you attach the OEM latch to it or if it’s strong enough to attach at a single point to a big sheet of plastic. I don’t want to get involved with hood pins.
S class hood vent
http://i63.tinypic.com/296cfo8.png
Vent placement
http://i67.tinypic.com/19mrlz.png
Second order of business is rear aero, and I think I might actually be smoking a crack pipe. HPDE events require us to run with the driver and passenger windows down. I’ve got no back seats and a clear path to the trunk. What if I cut a rectangular hole in the trunk behind the license plate, allowing air to flow through the windows and out the back? In normal driving I’ll have the license plate on but at the track I can take it off and expose this vent. It should completely destroy the low pressure zone behind the trunk and make the whole cabin into a spoiler.
I also highlighted some spots where I’m going to trim away the rear valance to let the rear wheel wells vent better (the liners are 1/3 removed).
