Don’t take it the wrong way. Not saying u can’t drive. But let’s all recognize that we all leave time on the table, and I can plainly see a lot of opportunity from your vid. You are consistent–that’s great and it means when u find those time improvements u can consistently deliver those laps.
You do this funny steering wiggle thing mid corner which IMO, given the amount of correction u are doing, it’s unnecessary and u are better off using the throttle to keep the weight transitioned rearward (read: more grip on the back tires). And u brake so much for some corners that you are getting back on the gas hard way before the apex–even on corners that do not go downhill… That’s definitely costing u time. U know the track and the lines. I do not doubt it. I have no critique for the lines u take. But on a driver input level, there is definitely time left on the table. If the car is squirmy, tire pressures can be adjusted. If pressures are perfect, then rebound can be adjusted. But I say before adjusting anything,address the braking thing first. Focus on those corners. I can rewatch the vid and call out the corners where this occurs if it helps.
I should also mention spec miatas can do sub 1:40 at Laguna seca. I don’t really care what cars one is passing around a track. It’s the nut behind the wheel that counts.
