Took the day off of work today to get more done on the car. I would have gotten more done, but I spent a good portion of the morning driving around looking for a 12 point 8mm socket. I finally found one at Lowes and was back in business.
If you haven’t already, remove the sprocket/gear from the exhaust cam now with a puller. It’s a bitch, have fun. I used a medium size 3 jaw puller with a little PB Blaster. Then remove the black cover that was held in place by the sprocket you just removed.
I started by unbolting the cam tray from the head. Once all the bolts are out, use a screwdriver to pry slowly around the perimeter on the cast tabs to lift the cam try off the head. I forgot to take pictures of this part, but it’s easy to figure out.
Once the cam tray is off, you can remove the cams. Press down on the tensioner (if it’s not already compressed), and hold it in place with a small allen wrench. Now lift the front of the cams out of the head and move them toward the back of the head to get the chain clear from the tensioner.
Now that the cams are out, we can get to the rocker/lifters. Pull these out simply by lifting up. I don’t know if it’s a big deal with these, but I kept them in order so I could put them back in their original spot.
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpsjrmlcbda.jpg
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpscyf7u2d6.jpg
With those out of the way, we can get a better look at the valve springs.
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpsaughmqbf.jpg
Bolt on the valve spring compressor and strap the head down to your work bench. You don’t want this thing moving around on you. It will make a difficult job much worse.
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zps7rzsfsjk.jpg
My method for removing the springs was to fish in a small telescoping magnet pickup thingy down in the head to snatch up the valve keepers while the spring in compressed. A lot of them were pretty stuck, so I had to free them with a small pick before grabbing them with the magnet. There is no way I could have taken a picture of this without a helper. Repeat this 16 times and swear a lot, until you get all the valve springs off.
With the springs off, use some valve seal pliers to remove the old seals. It helps is you twist them before pulling to break them free.
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zps2cifxgxc.jpg
Now you can remove the valves. Be sure to keep track of which one goes where, or you may have valve sealing issues later. Each valve is mated to it’s specific seat. I used a box with holes in it to keep them all in order.
At this point I had a completely bare head. Seems like a great time to get out the Harbor Freight soda blaster and do one hell of a carbon cleaning. Earlier in this thread, there are pictures of the back of my valves. The underside looked pretty nasty on cyl. 2&3 also.
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpsq40zlai2.jpg
I spent the next 2 hours or so blasting the crap out of the head. I sprayed the head down with brake cleaner to get rid of the oil prior to blasting. The soda blaster also works wonders for removing the sealant from the head and cam tray. I also blasted each valve individually while it was out. The buildup on the exhaust valves is damn near impossible to get off, so I settled for scraping off what I could with a razor blade and calling it good.
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpscpylsaz6.jpg
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpsao06lkzd.jpg
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zps1tvcmvtl.jpg
After I finished blasting, I hosed out the head thoroughly with water. The soda dissolves easily, so you don’t have to worry about any getting caught in the water/oil passages. After hosing it out good, blow it dry with compressed air.
Back to the workbench to reinstall the valves. I coated the stems with clean engine oil before installing.
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zps3dds9ywv.jpg
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpsp0b8exlo.jpg
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpsdyet2ueq.jpg
With the valves back in, strap the head down to the bench again and install the new seals. I used IE seals and they are different between intake and exhaust, so make sure the right ones go in the right spot. The exhaust seals are made from Viton to hold up better to the heat and are blue. The intake seals are reddish brown and I think are just rubber. I pushed them on by hand and then seated them with the valve seal pliers. After you install them, make sure you didn’t damage the small spring that goes around the top of the seal.
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpsibwqemvj.jpg
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpsiabf6gmg.jpg
Now comes the shittiest part of the entire job IMO. You have to compress the springs back over the valves and install the keepers to hold them in place. After lots and lots of swearing, this is what I came up with:
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpse0ll5igd.jpg
The pipe on the compressor tool gives me a lot more leverage, making it easier to keep the springs compressed. I tucked it under my arm, and used my body weight to keep the spring compressed. This lets you use both hands to fumble fuck with those little demon keepers. I used a small magnetic (barely) screwdriver and a non-megnetic screwdriver to position the keepers. You will get the hang of it after 2-3 of them, but that doesn’t mean it will be easy. It still sucks.
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpssbsj8zmy.jpg
After all the springs are back in, I used a scrap piece of aluminum I had and a hammer to give head valve a few good whacks to make sure the keepers and spring retainers aren’t going anywhere.
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zps3jikmhvk.jpg
Put the rockers/lifters back in.
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpswjgl9qte.jpg
Reinstall the tensioner. You can see the allen wrench that is keeping it compressed. I also put a thin coat of bearing assembly lube on the cam bearing races before putting the cams in.
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpsp9dvbwus.jpg
Lay the cams in place in the head. If you left the chain on them like I did, this part will be easy. If not, use trial and error until the timing tool will fit between the cams.
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpsbditdft4.jpg
Lube up the cam tray.
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpsartgktcx.jpg
Place the cam tray over the cams, and tighten in place with a couple bolts. This is a good use for your old cam tray bolts, since they are TTY and you need to use new ones. You are just doing an additional check of the cam timing here. The timing tool should easily fit between the cams with the tray tightened flush with the head.
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpsrzhctnda.jpg
After you are certain the cams are properly timed to each other, bust out the sealant. I used Elring Dirko sealant. It’s much cheaper than the Audi sealant and will likely be much easier to remove if I ever need to. Put a small bead of sealant on the cam tray in the machined grooves around the perimeter and the plug holes. Don’t go overboard, just use enough to have a bead the width of the groove. This is when you want to install your new cam seals. I also used some ARP fastener lubricant on my cam tray bolts per ARP’s recommendation. I torqued the cam tray bolts to 15 ft-lbs. starting from the center and working my way out. I believe the stock bolts are 8 nm and 90 degrees (you should double check to be sure).
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpss8dil9r9.jpg
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpsz0bupabi.jpg
After that, pop the timing chain cover back on and call it a night. This was about the time that I realized I was starving because I hadn’t really eaten anything all day.
http://i10.photobucket.com/albums/a129/2fast4sanity/image_zpsxivxtkas.jpg
