[quote=“saxon,post:178,topic:5032”]
that has everything to do with market size. Are you an engineering student who doesn’t understand how the real world works? Making a 2900 lb 2wd econobox go fast is easier for a few reasons
- the market is 40 fold what the market for even the B8 S4 is so it’s saturated with options, and people have cleared the path and drawn you a map already
- the cars are cheap as chips, so people will push them to within an inch of their life, and if they blow up a motor, it’s a $500 trip to the wrecking yard to replace it, and $1000 in aftermarket internals to be back up and running. A new engine for a B8 S4 will cost you about the same as the entire econoshitboxes in the ricer world you’re used to were new.
- ricers run their cars in a form that most people on this forum would vomit at the thought of having to ride in. A loud, fart can, 4 cylinder, stripped out shitbox with a tinny plastic interior and the lumpiest most embarrassing idle is hardly what people buy $60,000 cars for.
So answer the questions…are you retarded enough to buy an EPL tune without seeing ANYTHING impressive from EPL EVER? That means you’re the only true fool on this forum. You got fooled and sucked in by a gimmick.
cant wait til AMS brings some performance to the table and then you will all say " there is no way they are doing that safely, they have altered code they shouldnt have and it will blow up"
