Take what I’m saying with a grain of salt as I’m not impartial. Here is some perspective.
JHM had several cars. Both in house and customer cars that were S6 and S8 5.2 V10s. I guess you can say they custom tuned the cars. They custom tuned their test car and found the formula that worked and make GOOD power and unquestionable acceleration improvements. They then put that on the other cars. Logged and validated the results were consistent. From there they tested and improved on the dyno and street over the next several weeks to months. Testing in all kinds of conditions.
A JHM tune is more than just a WOT tune. How often do you drive WOT? Honestly? 90% of the time your part throttle or mid throttle.
JHM tuned not just for WOT throttle getting world record breaking results but, they looked deeper into the tune, into the part throttle, low throttle, off throttle. They tested on the dyno, then the street then the track and then in the city, stop and go traffic long road trips and they did this over MONTHS not minutes. Gathering data each step of the way improving each step of the way.
Do you drive to work on the dyno? I don’t, if you do, and you only drive WOT to work on a dyno… I don’t know how you actually would get to work that way but, if you tune your car that way your leaving 90% of the usable power untapped. Going to just get a dyno tune you’ll probably not make any power than the JHM tune currently makes. It’s not like JHM didn’t test already on a dyno for the best repeatable results.
IMHO A proven tune (canned or not) is better than an untested, unproven tune. The JHM tune has been producing the same results acceleration wise all over the world. It’s consistent and proven. You can always say. Oh there might be a few extra hp left. Maybe you can eek out something here or there. But at what cost?
This is the best quote so true —
I’ve been on the dyno and I’ve known TONS of domestic tuners who make a load of cash doing “custom tunes” all that means is in most cases they load up a tune that they know works for that combination and they dyno the car. Because if you’re a real tuner. You know X or Y combination needs this AFR, This ignition, this cam angle etc etc.
What’s so custom that needs to be tweaked? We all have the same MAF, Same cylinder heads, same throttle body, same motor, same camshafts, same injectors, same intake manifold the list goes on.
If you put in new injectors, build a custom intake manifold and then do major cylinder head work. Sure maybe a custom tune wouldn’t be a bad idea to look at. But for a 90% stock car IMHO a custom tune is a waste of your money and time. Especially when you have a tune like the JHM tune that has been performing so well for so long. There is no guess work. You already know what your getting.
For me, I’d rather have a tested tune that has been working strong and safe all over the world over the past several years with years of testing on the street and at the track. Vs someone who has little not no experience with the platform and is testing on my car on the dyno try try and make power.
But that’s just my take on it.
. Some of them are on here lurking. I guess haters gon’ hate.
