Howdy,
$8500 spent and I have another oil leak
Have done oil filter housing and front crank pulley. Have checked front drain holes that drain from under the intake manifold to eliminate a faulty seal or anything under he intake manifold and they are all bone dry this time. It is above the lower oil pan and oil drops are comming from the middle apart from the dreadful upper oil pan seal which I’ve heard is a engine out job is there anything else I should be looking for.
Not valve gaskets have done those. Have got under carriage tray off and seems to be more on the left hand side of the motor but definatly at the front.
Heeeeeelp
