APR R8 TVS1740 Supercharger System Released
APR Presents the R8 4.2L FSI V8 Stage III+ TVS1740 Supercharger System!
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_system.jpg
Product Page
APR is pleased to present the R8 4.2L FSI V8 Stage III+ TVS1740 Supercharger System!
APR’s technical reach has grown enormously since opening in the 1990’s and currently represents a force of unmatched performance without compromise in the performance enhancement sector for Audi vehicles. Our previously available APR Stage III TVS1320 Supercharger System found its way on to several hundred 4.2L FSIs around the world, making it the most popular and reliable system on the market. With more than four years’ worth of 4.2L FSI supercharger engineering research, development and testing, APR’s new Stage III+ TVS1740 Supercharger System represents the pinnacle of Audi’s German engineering enhanced by APR’s American ingenuity.
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_installed.jpg
In the factory form, Audi’s high revving FSI V8 can leave much to be desired compared to some of the latest technological advances brought forth by Quattro GmbH in recent years. The APR Stage III+ TVS1740 Supercharger System fills the void by adding an average of roughly 46% more horsepower and torque across the entire power band. The results are nothing short of amazing; taking the R8 from 425 horsepower to 642 horsepower on pump fuel and 689 horsepower on race fuel without breaking a sweat! With 550 FT-LBS on tap thanks to the TVS1740’s positive displacement supercharger expect instant acceleration with absolutely no lag commonly associated with other forms of forced induction.
Video:
https://www.youtube.com/watch?v=b6rBbXRIOV4
Supercharger, Manifold and Runners
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_supercharger_1_mid.jpg
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_supercharger_2_mid.jpg
At the heart of the APR Stage III+ Supercharger System is Eaton’s latest Twin Vortices Series (TVS) supercharger unit, the TVS1740. The supercharger system is a positive displacement, roots style pump, utilizing Eaton’s lightweight, four-lobe 160 degree twisted rotors. Cast and assembled as a single, OEM-style-manifold and rotating group housing, the unit is quiet, compact, attractive, easy to install, and requires little to no extra maintenance to the unit itself.
The positive displacement supercharger offers power instantly as the throttle is pressed. Boost pressure builds with no perceived lag commonly associated with other types of forced induction, and provides a large increase in torque across the entire power band. Throttle control is linear and predictable and makes for an excellent driving experience both in daily driving and wide-open acceleration.
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_supercharger_3_mid.jpg
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_supercharger_4_mid.jpg
Since the supercharger does not compress air as it moves through the roots, it’s extremely efficient during light throttle and cruising situations. Unlike screw-type positive displacement superchargers that are always compressing, the TVS unit can internally bypass unwanted air, resulting in negligible parasitic loss during cruising and thus far greater fuel economy.
The single cast unit and appropriately sized rotating group eliminates potential leak points and allows for a slim, compact design without sacrificing key airflow design characteristics. The unit features a high velocity flow path through the supercharger rotors and an unrestricted discharge port into the appropriately sized plenum. The large plenum equalizes flow across all ports as air feeds evenly through the low-pressure-drop, dual-internal air-to-water heat exchangers. Finally, the ports are separated into individual runners and continue through aircraft grade 6061 billet aluminum extension runners, offering greater operation by eliminating cross talk.
Internally the dual heat exchangers offer technological advances shared by Formula 1 teams around the globe. Each unit features a louvered fin design, which minimizes pressure drop while achieving excellent cooling effectiveness. The extruded multi-rib tubing maximizes heat extraction to be carried away through the large bore coolant recirculation hard lines. Externally, supercharger coolant is pumped through a large front mounted heat exchanger where it’s cooled and circulated back through the charger again.
Engine Management
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_ecus_mid.jpg
The factory Bosch MED 9 engine management system is responsible for proper operation of the engine during constantly changing environmental and load conditions. With built in compensational data for environmental variables and varying load conditions, the factory ECU is far more complex and intelligent than units found in other vehicle makes and marques.
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_dyno_mid.jpg
With the significant amount of changes included in the APR Stage III+ TVS1740 Supercharger System, APR’s Engineers spent months calibrating the engine management system, including well over 100+ hours of in-house chassis dyno development. Drivability, gear changes, cruising and part throttle operation were tuned to operate smoothly as if intended by the OEM. Further development was performed putting the vehicle through performance evaluation and durability testing at the drag strip. APR’s Electrical Engineers built new coding functions, strategies and routines into the ECU to control conditions normally unseen at factory power levels. Thanks to APR’s incredible proprietary calibration suite, data logging software and full access to the coding structure of the ECU, appropriate and intelligent changes are made to ensure flawless drivability and excellent performance without compromise.
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_road_mid.jpg
Adding forced induction to a naturally aspirated engine presents several challenges with regards to how the ECU operates. APR’s Calibration Engineers properly restructured the engine’s volumetric efficiency (VE) model to properly determine the ECU’s calculated load. Accurate open loop fueling is achieved, translating to insignificant fuel trim adjustments. Closed loop fueling is calibrated to control lambda perfectly under all operating conditions. Furthermore, compensations, such as ones related to intake air temperature, are adjusted to handle the large temperature variances compared to a factory naturally aspirated setup.
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_track_mid.jpg
APR’s Calibration Engineers have optimized cam timing, ignition timing and lambda to provide tremendous leaps in power while retaining OEM knock control sensitivity. The result is safely achieved power, optimized for various fuel grades found around the world from low quality pump fuel, all the way to high quality, oxygenated race fuels.
Beyond power and torque enhancements, APR’s Calibration Engineers were able to increase the acceleration rate of the vehicle through other calibration changes. Ignition delays are reduced resulting in a more responsive pedal without altering overall throttle sensitivity and resolution. Drivability was greatly improved by reducing the throttle lag commonly noticed at slow speeds and while reapplying throttle after decelerating. APR’s Motorsport Rev Limiter allows power to climb all the way to the factory set redlines without dropping off several hundreds of RPM earlier. And lastly, APR’s tried and tested 4,200 RPM Motorsport Launch Limiter allows the driver to focus on launching the vehicle, rather than controlling the engine speed.
Beyond wide open throttle performance, APR’s Calibration Engineers spent countless hours optimizing vehicle drivability under daily, part-throttle, driving. The vehicle’s pedal maps are recalibrated under both standard and sport mode, providing smooth part-throttle drivability without compromising the driveshaft windup protection. The vehicle fully retains its impressive daily driver status and simply has more power on tap should the driver request more with his or her right foot! We call it Performance Without Compromise.
Supercharger Coolant Air-to-Water Radiators
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_radiators_mid.jpg
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_radiator_details_mid.jpg
APR’s supercharger system features a large, 585 mm x 140 mm x 65 mm front mount radiator and a second 320 mm x 140 mm x 90 mm side mounted radiator responsible for cooling coolant as it’s pumped out of the supercharger’s dual internal air-to-water heat exchangers. An adequate cooling system is critical in any supercharged application to not only keep power consistent, pull after pull, but also to help keep IAT below dangerously high levels.
The heat exchangers are specific to the R8 platform and feature cast aluminum end tanks with threaded connection points and bleeder valves. Each cooler cleanly installs with the supplied CNC, laser-cut brackets, complete with vibration insulators.
Supercharger Coolant Pump, Harness and Bracket
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_pump_and_harness_mid.jpg
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_pump_mid.jpg
The R8’s rear mounted engine results in a supercharger cooling circuit spanning over twenty feet and calls for a high quality coolant pump. As such, APR’s supercharger cooling system features a highly efficient brushless cooling pump feels right at home in the R8’s engine bay.
The military grade coolant pump seamlessly connects to the factory wiring harness through the included APR wiring harness with no wire splicing and is triggered by the included relay system.
APR’s CNC, laser-cut bracket provides a simple and clean method of mounting the pump to the vehicle, out of sight, and vibration isolators ensure the system runs as quietly as possible.
Supercharger Coolant Expansion Tank
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_coolant_tank_mid.jpg
The APR coolant expansion tank is used for filling the supercharger’s cooling circuit and for handling liquid expansion under various operating temperatures. APR’s CNC, laser-cut bracket provides a simple and clean method of mounting the expansion tank to the engine bay out of sight. The alumnium tank is anodized black and features a machined APR logo.
Supercharger Coolant Lines
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_coolant_hoses_charger_mid.jpg
The APR Supercharger System features dual internal air-to-water radiators designed to reduce intake air temperature, (IAT), before entering the cylinders. With cooler IAT, the ECU will request more ignition advance and result in more power.
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_coolant_hose_closeup_mid.jpg
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_hose_detail_mid.jpg
A multitude of coolant lines feed the supercharger’s internal cooling system, which provides a circuit between the included radiators, coolant pump and expansion tank. Longer lines, such as those running the full length of the car, feature threaded connections, braided stainless steel outer sleeves and reinforced rubber cores. Specifically routed hoses are made from multi-ply silicon and the remaining hoses are flexible, reinforced rubber. All necessary brass connectors, spring-loaded clamps and OEM style crimp clamps are included.
The factory engine coolant hose running beneath the supercharger is modified for fitment reasons and is constructed from a high quality, multi-ply silicon. Protective covers are provided to shield against abrasion.
Intake System and Air-Oil Separator Bracket
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_intakes_mid.jpg
Two high flow K&N filters are adapted to the factory air box to provide fresh filtered air to the supercharger. The factory MAF housing bolts to the metal filter bracket and connects to the throttle body via two multi-ply silicon hoses. The ultra-ridged design ensures the hoses will not collapse under the tremendous vacuum created by the supercharger system’s newly added forced induction.
Laser-cut, CNC-bent air-oil separator brackets reposition and secure factory PCV system beneath the intake system.
Supercharger Pulley System
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_pulley_system_mid.jpg
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_pulley_bracket_back_mid.jpg
The supercharger system’s internal rotors are rotated via a belt and pulley attached to the engine’s accessory drive system.
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_crank_pulley_mid.jpg
APR’s upgraded the R8’s belt system to utilize a 6pk belt for additional strength. A new cast and CNC machined bracket is used to properly orient the circuit and features new OEM tensioners, and idler pulleys. The harmonic balancer is upgraded to an OEM replacement, high quality, balanced 6 rib unit.
Engine Oil Relocation System
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_oil_relocation_mid.jpg
The APR supercharger system’s casting features a large, high flow, dual throttle body inlet system, which provides a high velocity flow path to the supercharger roots. To incorporate this feature into the design APR’s engineers were required to move the factory oil filter.
A CNC-machined billet-aluminum adapter connected to the oil feed and return and provides a connection point for high quality, braided stainless-steel oil lines. The lines route to the new black-anodized CNC-machined billet-aluminum oil filter housing.
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_oil_housing_mid.jpg
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_oil_adapter_mid.jpg
CNC, laser-cut brackets cleanly hold the housing in place and out of sight under the factory engine side covers. Conveniently oil changes are now made easier with quick and easy access to the filter.
High Pressure Fuel Pumps
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_hpfps_mid.jpg
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_hpfp_internals_mid.jpg
Sold separately as brand new pumps or rebuilds of the engine’s existing pumps, the APR High Pressure Fuel Pumps address fueling needs and leaves plenty of headroom for safety and further increased power levels. By increasing the pump’s internal capacity, the fueling system is capable of displacing a higher volume of fuel per minute at every RPM. Read more on our APR High Pressure Fuel Pumps product page.
Fueling System
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_fueling_mid.jpg
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_rpv_mid.jpg
To accommodate the large APR Supercharger, modifications are made to the low-pressure fueling system and evap lines. Each fuel line exceeds CARB and EPA ratings and includes a patent-pending GreenShield barrier. The multi-ply, reinforced rubber hoses are designed to protect against today’s modern deteriorating fuels and include a best-in-class working psi of 225.
OEM style spring clamps and crimp clamps are included to ensure a solid connection. The included mounting bracket allows for a clean and solid install of relocated components.
Intake Air Temperature Sensors and Harnesses
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_iat_sensors_mid.jpg
The factory mass airflow sensors include intake air temperature (IAT) probes and are designed to provide the engine control unit (ECU) with air temperature information. Because the R8 is converted from naturally aspirated to forced induction, the sensors must be relocated to ensure proper IAT measurement. The IAT sensors are absolutely critical for safe, reliable and powerful operation and as such, APR provides two OEM sensor and harnesses for placement just past the supercharger’s dual internal air-to-water radiators. The included harnesses allows for simple integration into the OEM wiring harness and comes preinstalled in the supercharger.
The sensors feed correct IAT readings to the ECU, which provides closed loop control over various calibration decisions, such as desired ignition advance. This provides safe operation no matter what the condition. During a cold day, with lower supercharger coolant temperature, the ECU will safely increase engine output mainly through ignition. However, under hot conditions, such as a vehicle seeing plenty of track time, the ECU will compensate for these conditions, lowering output slightly to avoid dangerous premature detonation. These compensations result in only attempting to safely achieve the maximum amount of power capable during any given temperature related scenario.
Engine Coolant Hose
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_coolant_hose_engine_mid.jpg
The APR Supercharger fills the valley between the cylinder heads and as such, the factory coolant hose was redesigned to accommodate the supercharger. The specifically routed hose is made from multi-ply silicon and features a protective cover to provide a shield against abrasion.
Vaccum Lines
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_vacuum_mid.jpg
To accommodate the transition from naturally aspirated operation to forced induction, APR provides new vacuum lines and junctions. Leak proof connections are easily achieved thanks to the included OEM style crimp clamps.
Spark Plugs
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_plugs_mid.jpg
To cope with raised cylinder pressure and temperature, eight NGK Iridium IX spark plugs are included. The plugs operate at a heat range colder than stock, which results in better pre-detonation resistance under extreme conditions. With these spark plugs in, APR’s calibration engineers were able to safely achieve more power, especially in extremely demanding conditions.
Gaskets and Hardware
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_gaskets_mid.jpg
New OEM gaskets and bolts are provided to facilitate a leak proof connection between the cylinder heads and APR Supercharger runners.
Fender Liner
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_fender_liner_mid.jpg
The side blades on the Audi R8 provide an excellent mounting location for further supercharger air-to-water radiators. The APR Supercharger System utilizes a vented R8 V10 fender liner to allow proper airflow through the air-to-water radiator and in doing so, borrows an engineering design element from the V10 platform. The fender liner installs cleanly without any destructive trimming to the factory parts.
Install Manual
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_install_manual_mid.jpg
APR has a worldwide network consisting of many professional shops capable of performing an APR supercharger system install. To accompany APR’s world-class technical support hot line, APR includes a full, printed, step-by-step install manual to make the install process smooth and simple!
Dyno Testing
Horsepower and Torque was measured in APR’s in-house, soundmaster dyno cell, using a dynapack all wheel drive dynamometer. Multiple stock and modified runs were conducted and the SAEJ1349 corrected results were averaged together to represent the differences between a stock and APR Stage III+ R8. Crank power figures were estimated based on Audi’s factory advertised results.
Click through the tabs below to view output using various fuel grades, power measured at all four wheels, estimated at the crank, and the absolute gain over stock.
http://www.goapr.com/includes/img/products/dyno/42l_fsi_v8_r8/r8_42l_fsi_s0_vs_s3+_93_cc.png
Click the links below to see power output at the wheels, estimated at the crank and with different octanes
91 Octane | 93 Octane | 100 Octane - Measured All Wheel Horespower
91 Octane | 93 Octane | 100 Octane - Estimated Crank Horsepower
91 Octane | 93 Octane | 100 Octane - Gain over Stock
APR Stage III+ TVS1740 Supercharger System Calibration Report
Output:
424 HP & 317 FT-LBS of Torque - Stock as Rated by Audi
425 HP & 318 FT-LBS of Torque - Stock as Measured by APR
611 HP & 511 FT-LBS of Torque - APR Stage III+ with 91 AKI or 95 RON fuel
642 HP & 526 FT-LBS of Torque - APR Stage III+ with 93 AKI or 98 RON fuel
689 HP & 550 FT-LBS of Torque - APR Stage III+ with 100 AKI or 104 RON fuel
Max Gains over Stock:
+200 HP @ 5,350 RPM & +200 TQ @ 5,100 RPM - APR Stage III+ with 91 AKI or 95 RON fuel
+220 HP @ 5,600 RPM & +214 TQ @ 4,950 RPM - APR Stage III+ with 93 AKI or 98 RON fuel
+263 HP @ 7,900 RPM & +239 TQ @ 5,900 RPM - APR Stage III+ with 100 AKI or 104 RON fuel
Acceleration Testing
All too often performance upgrades show improvements during a single dyno pull, but lack the ability to show the same performance in real world conditions. Furthermore the dyno may be unable to illustrate the system’s response and other tuning changes designed to make the system instantly react to the drivers input. Through acceleration testing, APR’s engineers were able to improve power delivery during launches, after gear changes and prove the cooling system was up to the task of sheading heat to keep power consistent.
APR’s local certified quarter mile drag strip is a perfect and safe testing ground for high speed, 130+ MPH sprints. Using Car and Driver magazine’s measured results as a benchmark, APR’s Engineers setout to prove the Stage III+ Supercharger System was capable of increasing the R8’s performance substantially.
Car and Driver magazine measured the R8’s sprint from 30-130 MPH in an underwhelming 17 seconds. However, with the addition of the APR’s Stage III+ TVS1740 Supercharger System, the vehicle entered a league of performance often shared by exotic supercars. Using 93 octane fuel the same acceleration test was completed 6.5 seconds faster! Through testing higher octane fuels, and eventually weight reduction and tire changes, the gap grew even larger, ultimately resulting in an astonishing 44% reduction in time.
Many more acceleration tests were performed, including record setting quarter mile passes, proving an APR Stage III+ TVS1740 Supercharger System is the ultimate upgrade for R8!
http://www.goapr.com/includes/img/products/dyno/42l_fsi_v8_r8/r8_42l_fsi_s0_vs_s3+_0-130mph.png
0-60 MPH
4.20 - Stock (Car & Driver Magazine)
3.61 - APR Stage III+ - Full Weight with Street Tires and 93 AKI Fuel
3.34 - APR Stage III+ - Full Weight with Street Tires and 100 AKI Fuel
0-100 MPH
10.60 - Stock (Car & Driver Magazine)
6.91 - APR Stage III+ - Full Weight with Street Tires and 93 AKI Fuel
6.31 - APR Stage III+ - Full Weight with Street Tires and 100 AKI Fuel
60-120 MPH
10.7 - Stock (Car & Driver Magazine)
6.57 - APR Stage III+ - Full Weight with Street Tires and 93 AKI Fuel
6.03 - APR Stage III+ - Full Weight with Street Tires and 100 AKI Fuel
60-130 MPH
14.30 - Stock (Car & Driver Magazine)
8.69 - APR Stage III+ - Full Weight with Street Tires and 93 AKI Fuel
7.88 - APR Stage III+ - Full Weight with Street Tires and 100 AKI Fuel
30-130 MPH
17.00 - Stock (Car & Driver Magazine)
10.49 - APR Stage III+ - Full Weight with Street Tires and 93 AKI Fuel
9.56 - APR Stage III+ - Full Weight with Street Tires and 100 AKI Fuel
Requirements and Recommendations (Each Sold Separately)
The APR HPFPs expands the 4.2L FSI V8’s direct injection fueling capabilities to the levels required for proper operation with the APR Stage III+ TVS1740 System. Because the pumps are sold in two different forms, they are offered separately from the kit. Entirely new pumps can be purchased, or the vehicle’s existing pumps can be sent to APR for a rebuild at a discounted rate. This product is required.
Transmission
The APR Supercharger System greatly increases torque over the factory output levels and as such, an upgraded clutch may be necessary to transmit power to the ground. APR highly recommends upgrading the factory clutch to one that suits the operator’s intended driving style.
Induction System
The APR Supercharger System was designed using the factory intake system with the included K&N Filters and OEM mass airflow (MAF) sensor housings. An intake port carbon cleaning is necessary to meet advertised power levels.
Exhaust System
The APR Supercharger System was designed for operation with the either the factory exhaust system or a high flow exhaust system.
Motul Fluids and Lubricants
Maintaining the vehicle’s fluids and lubricants is necessary. APR highly recommends Motul’s product range.
Application Guide
Audi R8 4.2L FSI V8 Coupe with 6 Speed Manual Transmission (R-Tronic currently under development)
Part Number T3100054
Price $23,749.99
Motul Oil and Coolant
http://www.goapr.com/includes/img/labels/motul.png
During the install, oil and coolant must be drained and should be replaced to offer superior performance and protection. The APR Supercharger Systems are now complete turnkey solutions, including everything you need down to the oil, coolant and oil filter. During checkout you’ll be given the option between Motul Specific 502.00, 505.00 & 505.01 5W40 or Motul Power 300V engine oil as well as Motul Inugel Optimal Ultra Coolant. The Premium Motul lubricant package is included at a much lower than retail price point and the costs are listed below.
Motul Specific Lubricant Install Package
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_specific.jpg
10 Liters of Motul Specific 505.01, 502.00 & 505.00 SAE 5w40 Oil & 9 Liters of Inugel Optimal Ultra (Concentrated) - Organic
Part Number: MO00015
Price: $125.00
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_300v.jpg
10 Liters of Motul 300V Power 5W40 & 9 Liters of Inugel Optimal Ultra (Concentrated) - Organic
Part Number: MO00016
Price: $165.00
How to Contact APR USA or an APR Dealer
Website: www.goapr.com
Dealer Locator: www.goapr.com/dealer
Phone: +1 (334) 502-5181 or 1 (800) 680-7921
Email: apr@goapr.com
Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
Facebook: https://www.facebook.com/APRMotorsport
Twitter: https://twitter.com/goapr
Youtube: https://www.youtube.com/user/APRVideos
Flickr: http://www.flickr.com/photos/goapr/
Nice… Lunch time reading… GO APR!!!
any 1/4 mile results, or are you holding on to those for a while?
http://www.goapr.com/includes/img/products/stage_3+_r842fsi_track.jpg
Thanks for sharing, Arin. Is that Schwarzenegger narrating the vid? lol
I think they’re holding back for now. Part of Arin’s post above:
[quote]Many more acceleration tests were performed, including record setting quarter mile passes, proving an APR Stage III+ TVS1740 Supercharger System is the ultimate upgrade for R8!
The product page on their website likewise lists 1/4 mile results as “N/A”
Nice!
Looking forward to 1/4 mile results too!
Will this fit my A4 ???
arin this is great. The kit looks very well made and put together. I think this is the cheapest R8 kit too…
The times were still record setting for the 4.2L R8 as far as I know, but there’s way too much head room left for me to advertise those results.
Thanks. That would be surprising. It wasn’t cheap on our end to say the least and the laundry list of included parts is quite lengthy.
Wow great price. Cheap for a “supercar” modification.
Details on that intercooler pump? It just looks weird. Is that an OEM pump used in some other application? .
Cross section of the intercoolers?
Yeah, you don’t want to show till you have something special.
As for fastest 4.2 it would likely be the turbo guys in Europe. MRC I believe and someone else who I can’t remember. They were running in the 11s @ 130 MPH.
The 80% rear bias certainly makes it a bit tougher for the R8 than maybe the other Audis.
Can’t really give out any deails on the MFG at the moment. It’s pretty bad ass though. : )
I’ll shoot one later. I have a cut away I would like to photograph.
Yeah, those should be fast. Built motor? IIRC they said some ridiculous numbers.
I’ve seen stock, bolt ons, and VF TVS1900 times. Nothing from PES worth mentioning or any of the single or twin turbo kits, nothing from any of the rotrex kits, or other centrifugal kits. If you know them, post up the results.
Don’t know what MRC did to the motor. Their ET was suffering like yours.
Single turbo. 11.70 @ 128. 6
MRC Tuning Audi R8 Turbo V8 at Santa Pod Raceway: http://youtu.be/D-mOaokz0uk
was this tested on 6spd or r-tronic? How will it work with a 2014+ model using the new s-tronic?
This one’s fast but I can’t read the tinr/mph
GTI International R8 V8 Turbo vs RS4 Supercharged: http://youtu.be/h8mnpROb4js
11.7? Got that licked, but that 135 though… may need lots of race fuel. ; )
I know this is an old post. But did we ever get results for the kit.
I did notice that once again the turbo kits don’t outperform the well made supercharger kits.
what kind of results? Check the supercharger argument thread.
I know a guy running this kit on his 2008(?) 6MT. He’s gone to the strip before with it. I don’t remember what times he was getting.
But he’s been tracking the car now, I believe has done 3 track days with it at Grattan and is going to mid-ohio with me in a couple weeks. No issues from what I’ve heard. Rode with him and he hammered it pretty good. Hard to tell how fast a car is when sitting in the passenger seat lol
Here it was the night before the Grattan event
https://farm8.staticflickr.com/7656/17260124881_9469940e70_b.jpg
https://farm9.staticflickr.com/8693/16638209134_3c58d7df6f_b.jpg
