Last time I was at E-Town the guy over at Tech was telling me something about new cars being exempt from this rule… There was a GTR with a tune and E85 there running 10.6 and he said the same thing since the car is so fast from the factory… I wonder if that rule also applies to the TTRS…
From 1000 to 1320 they’d likely be only going from 120 mph up, top of fourth. You’d need more fuel in fourth than lower gears since there’s more time to spool, more IM pressure, and more detonation to quench. If there was a limit, makes sense it was reached here.
Awesome results for the second time out… Glad they keep going back and reporting results… Looking forward to seeing what the car done when they get whatever issues they are having resolved…
11.49 was time for a roll bar. 10.99 is time for a cage. Surprised Etown let them run in violation of NHRA rules. The big busy east coast tracks can be pretty sticky at times.
that’s not really true, but it sounds like that’s how they’re handling it. Makes total sense. Then you get the dorks who are by the letter of the law and kick you out. Our track had a GTR with tune and turbos trap 135 and get shut down immediately. Then there was a Mercedes SLR McLaren who went high 10s on one pass and they kicked him out.
The reality is that the safety rules are very important and trapping 130 mph means catastrophe if you crash. However eliminating all the fast supercars (who are NEVER going to roll cage their car) is bad for business. Tough call.
Considering how safe a $100,000 Audi is vs. a stripped fox body , they need some lee way
I don’t think fueling is a concern. If it were, I would expect the head ported setup on Jonnys car to cause problems first.
The HPFP we created is extremely large and the injectors are the largest Continental DI injectors in the VAG line up, as far as I remember. They are not like the older RS4 hitachi units (Similar to bosch HDEV 1). These are new multi 6 port injectors, similar to bosch HDEV 5. Basically, the old stuff sprayed from one hole. These have 6 holes. They also run at higher rail pressure than the RS4 so we can inject more fuel in a shorter period of time.
