While I’m excited for the bump in power, the real treat will be this DSG tune. Might grab some drag radials and give the 6k launch a shot. My apr dealer said he’d call me the second he can do it, release date looks like its pretty soon from what Arin is saying on AZ.
[QUOTE=Arin@APR;10700453]In short, you pick the max rpm when you flash the ecu.
Then we preset 3 different launch RPMs based on the value you set, and doesn’t go lower than stock.
At 100% throttle + holding the kick down switch, you get the max rpm launch.
At 100% throttle with the kick down switch not activated, you get a lower launch rpm.
Around 50% throttle (actually, a wide range under 100%) you get the low launch rpm.
Pick the one you want. Let go of the brake, go full throttle and hold on.
It’s great. One rpm could be for street tires on the street. The other for the track where conditions are stickier. Finally, track + really good tires. That’s how I would setup my car, but ultimately it’s up to you, your mods, and what your comfortable doing!
Video of the launch points:
https://instagram.com/p/2EzPuVAsAs/
