I thought it was a 2.7T with 2.8 heads and 1 turbo.
034 has a single turbo kit for the 2.7T but they think it will be usable on the 2.8 B5 A4. Should be interesting to see how that goes. Proabably under $6,000 installed. PITA job though.
Gt3788r. 2.8 block originally before the engine started knocking. Now I have a 2.7 block with RPM rods and a set of 2.7 heads with 2.8 cams. I am the first to build a and use a custom intake manifold on a 2.7 engine. I am also the first to use the 2.8 manifolds on a single turbo build.
Did mention that I built my car almost 3 years ago and I have the longest running single turbo build ever?
My employee is a b5 a4 owner. Goes to the track some, not the fastest et but traps 113 on a 1.8t. It’s his only car and drives everyday to work , about 70 miles round trip.
Aaron Saltsman aka “Salts”, finished his first version at least 3 years ago. It has undergone several large changes, and I believe he was parting it out to start all over again
I new who the pr¡çK was. He built his First flop just as I was putting my car together. He is the guy that sold guru the heart of his build (his intake manifold)
I only mentioned it because I believe it to be true. My car has been through a lot, but I keep it up and running. I went to the dyno yesterday with some known problems and put down 550whp/500wtq. I’m trying to make it to the track soon to see if I will be able to do better than 14’s. Also keep up the good work with the tunes you have been spitting out lately.
Thanks… 550/500 is no joke. I’m looking forward to seeing some good track times out of your setup.
I’m actually putting a pte 6265 single s4 on the dyno tomorrow morning to see what we can do with the clutch thats on there now.
