Audi C6 S6 v10 Info Dump
I have always looked at it like this.
The S6 and S8 are like the B6/7 S4 motors
and
The lambo motors are like the RS4 motors.
The same but different. The RS4 motors have better everything, it’s not that the B6/7 motors are really bad they are just not as good as the RS4
Great comparison.
I have spent some time looking into improving a local C6 S6 and there is a lot of room for improvement. In my opinion Audi made a fantastic engine and put it into a great car (both the S6 and S8) but they restricted it down really far so that it wouldn’t overshadow the current RS models of the time. Remember they had the B7 RS4 already out around the same time and then the C6 RS6 Avant came out in Europe. There was a purple D3 S8 that I worked on regularly and I loved every time he brought it in unless I had to check the power steering fluid. Here are a few things that I noticed.
Let me start with the intake.
  1. The intake tubing and air boxes are way too small. If you take off the top of the air boxes then you will see how badly the air filters are squeezed in there.
  2. They have a Soundpipe on the left/driver’s side. It probably slows down the intake air like the pipe that is on the B6 A4 3.0 V6. Look here for an explanation: http://audirevolution.net/forum/index.php?topic=96.0
  3. There is more than enough room to run a cold air intake like what the A6 3.0T guy did on the right/passenger’s side. Hell there is enough room to fit the JHM SC down there backwards like how JHM mounted it on the B8 S5. But the driver’s side has a secondary radiator in the way just below the headlight. I was going to move that secondary radiator in front of the main radiator and AC condenser with some brass fittings and longer coolant lines to fit a true cold air intake but that project never got off the ground.
  4. The intake manifold is cast magnesium like the B6/7 S4s so it gets heat soaked really bad. The engine gets hot as hell so some thick intake manifold spacers are needed to make a difference.
  5. The intake manifold is a dual path intake manifold like the B6/7 S4s for better low end torque and higher end horsepower.
  6. The change over is done by the Variable Intake Manifold Runner Motor V183. That part failed a LOT on both the Q7 version 4.2L FSI V8s and the 5.2L FSI V10s. There was an updated part to solve that problem. It was a nice repair on the V10s because I could replace the motor without moving the front end into service position but it still paid for those extra steps. If you ever have to replace that part then I highly recommend buying a bunch of the little tiny C-clips that hold the motor arms to the other linkages.
Lets move to the exhaust.
  1. The stock catback is tiny. I think a proper 2.75" catback from where the Y-pipes that connect the exhaust manifolds all the way back would help out a lot. These engines make between 429 to 444 horsepower stock which is just above what the RS4s make. The RS4s have seen a big improvement with 2.75" exhaust so why not on the V10s. Please don’t hold it against me if the members here with more knowledge think a 3" exhaust would work better.
  2. Those stock cats are really hateful. I took off the stock Y-pipes that connect the two exhaust manifolds together to change out the transmission fluid and filter. While doing that repair it looked like the cats for the front three cylinders on each side would be easy to gut. The cats for the rear two cylinders looked like a PITA to gut but it might be possible with a good long angled striking prybar, a big 3" or 4" wire brush attachment for a drill, and a few starts of the engine to blow all the crap out.
  3. Of course proper headers would be the best solution but it would be an extremely tight fit. Either way a good exhaust should sound fantastic.
Lastly I really see a weight reduction helping out these cars.
  1. The wheels are heavy as lead. They also use a odd tire size on these cars that are expensive.
  2. Those stock brake rotors are heavy as shit. I would be willing to bet a coke that JHM could shave over 10 pounds from the front rotors each. Even the rear rotors are heavy.
  3. All the C6 batteries are huge but they are also in the trunk like the B7 RS4s so I wouldn’t be so worried about it.
  4. The stock crank pulley is a fluid filled vibration dampener. It would be interesting if JHM came out with a lightweight front crank pulley to replace the stock unit.
Great info jbones. Always good to hear the real world perspective
Awesome writeup Jimmy!
Not many details on this one. From an S8, but the same usual suspects as the S6
V10 S8 in for some TLC, broken inlet manifold, flaps not working and heavily carboned up
http://ep1.pinkbike.org/p4pb11171867/p4pb11171867.jpg
V10 S8 all finished, carbon cleaned, manifold stripped, modified and cleaned and a pair of high flow filters to finish.
http://ep1.pinkbike.org/p4pb11171948/p4pb11171948.jpg
Here is a pic of the S8 engine, and the soundpipe to which Jbones is referring, along with the filter and airbox config. S6 is slightly different
http://ep1.pinkbike.org/p4pb11148861/p4pb11148861.jpg
You’d probably be able to figgure out some good information from the air filter part numbers and sizes. Have you checked into that?
07L133843B
07L133843E
Part number isnt really giving any more info. We will eventually be taking mine out for inspection, and will try and do some calculation to figure out if they are appropriately sized (CV believes they are likely undersized)
I bet they are properly sized. I installed K&N filters on the S6 that I did and they were the same size as stockers. Here is the info on them. Part number is E-2996
The flange the filter mounts to is 3.125"
The fliter itself is 6" diameter
The filter is 4.25" long.
Flatten that out and you have a panel that is almost 19" long and of course 4.25 wide. AREA: 80" (x2 filters so 160")
I seem to remember that the end of the stock factory filters are pleated and cone shaped, so that would add to the surface area of the filter.
S4 and RS4 filters are 10.3 x 8.25 so AREA is 84"
Thickness of the filter will probably make a difference here, but I suspect it is not enough to wash out the difference and put the V8 filter in the lead
Making up a measurement number for the hell of it. Square inches of filter per liter.
5.2 V10…30.8 per liter
4.2 V8…19.0 per liter.
SO the V10 filter sizes would appear to be plenty and not a major restriction. That airbox is tiny though. How much does a V10 S6 flow in CFM at WOT in optimal conditions?
Here are some pictures I have
Left and right airbox inlets and outlets. The filter is shoe-horned in there
Then left and right filters.
http://i183.photobucket.com/albums/x59/joec1992/DSCN2246.jpg
http://i183.photobucket.com/albums/x59/joec1992/DSCN2247.jpg
http://i183.photobucket.com/albums/x59/joec1992/DSCN2249.jpg
http://i183.photobucket.com/albums/x59/joec1992/DSCN2250.jpg
Flappy actuator
http://i183.photobucket.com/albums/x59/joec1992/DSCN2331.jpg
K&N filters installed
http://i183.photobucket.com/albums/x59/joec1992/photo-160.jpg
Great info Joe! Thanks!
The air filters were checked on my S6 today. MMMmmmmm… pretty :slight_smile:
http://ep1.pinkbike.org/p4pb11174723/p4pb11174723.jpg
http://ep1.pinkbike.org/p4pb11174724/p4pb11174724.jpg
User included pics
http://s1155.photobucket.com/user/delasem/slideshow/
I am not sure if I see cylinder wall scoring. Maybe on a couple of the pics. It is hard to tell with the photos being in extreme closeup. I see what looks like carbon on the cylinder walls.
I messaged the owner to see what exactly the garage is saying is the cause of the oil consumption.
What do you guys think?
looks like prototype cylinder wall scoring to me
http://i1155.photobucket.com/albums/p556/delasem/BK650061.jpg
http://i1155.photobucket.com/albums/p556/delasem/BK650063.jpg
Are those big chunks of carbon? At first glance it looks like the cylinder wall is flaking off, but I am guessing that is impossible, and wouldnt be black underneath. Must be carbon, no?
If so, can carbon mess up the cylinder wall that badly?
I’d like to know too. That can’t be carbon on the walls. It looks like it’s actually a hole in the wall. Those marks on the walls show a deep groove I can’t see carbon deposit being in a groove path.
Report of an S8 engine failure. Not many details…
[i][b]Engine in the S8 blew up on saturday cruising on the motorway at 100km/h, there is a piston on its way out on one side, and a conrod on the other. No warning lights at all, just went boom and died.
Short spec: 2007 S8 V10, 120.000km. Extremely well maintained and serviced every 10-15.000km.[/b][/i]
http://audisrs.com/archive/engine-in-the-s8-v10-blew-up__o_t__t_37270.html
A very knowledgeable source is telling me that the Lambo blocks do, in fact, come with some sort of sleeving. Ill post more info/pics on this if I find it
My interests in this project and an overall wonder for how each motor differs has had me searching for more information as well. I’ll try to go back and post what I’ve found. So far there does seem to be some kind of lining.
