Oh hey sorry I forgot about this
Hey guys for sometime the car would not recognize itās in park is there a switch or something that will cause that
Iām just doing some maintennance work on the car as I prep for winter. I thought Iād take another look at this problem. Do you have any kind of diagram that I can reference for the horn?
in my googling, I can find these part numbers, but no diagram or video showing the location of these items:
- Horn unit: 4F0951221a
- Horn wiring harness: 4F0971073
- Horn Relay 7.1: 4H0951253C
[UPDATE] Nevermind. I actually took the time to poke at the horn unit through the grill, and discovered (as I suspected) that the shop mechanic who replaced the front-end on the last job, did not lock the electrical connectors to the horn unit. They were just sitting there and I had to use a couple long screwdrivers to force them both into place.
Damn glad you found it and on my car too after my ridiculous times me removing my engine it has to be 6 or 7 times already I forgot to plug those shits in
Hey guys I finally started getting this code p3073 and it Seems like it can be multiple things causing this from me reading up on it . This is probably whats making the car run rough isnt it. Anyway does anyone what would cause this or how to specifically find out whatās doing this. also for a couple months the fuel gauge doesnāt work sometimes or doesnāt at all like if I put gas in itāll start working and be somewhat accurate or if Iām driving fast itāll just stop working and say e. The fuel gauge has gotten worse over the time itās been doing this
Literally looks like one of my knock sensors went bad from looking at the scanner
Knock sensor 2 circ low input
Does anyone know where that sensor is?
They are located under the IM
I mean specifically sensor 2
Like which one is what since there are 4 of them
Knock 2 is Grey connector lower front IM
Ok thank you
Your Welcome, so thatāll b bank 1 ( right side/P.S.) rear sensor against firewall.
For the life of me I still canāt figure out how to attach images.
Check the wires ECM side of plug, possible broken rt as it goes into plug⦠Had to solder/re wire all 4 of mineā¦
I looked at it. It looked fine
Hey guys Iām getting these codes
p3299 p1087 p1083
Would this be an exhaust leak?
