Very quick. Haven’t seen any tuned APR S5s run yet. Will be interesting to see how they stack up.
p.s. holy modlist
[quote]1. AWE Tuning B8.5 Stage 2 Pulley Kit with G.I.A.C. Stage 2 Performance Software
2. AWE Tuning S5 3.0T Performance Exhaust System with 102mm Diamond Black Tips
3. AWE Tuning Audi B8 3.0T Resonated Downpipes
4. AWE Tuning B8.5 S-FLO Carbon Intake Kit with S-FLO Filter
5. AWE Tuning ColdFront™ Heat Exchanger with Protection Screen
6. AWE Tuning ColdFront™ Reservoir
7. AWE Tuning ColdFront™ Coolant Pump
8. AWE Tuning Vent Mounted Boost Gauge with AWE Tuning 3.0T Boost Tap
9. G.I.A.C. DSG DL501 S-Tronic Transmission Software
10. H&R Street Performance Coilovers
11. H&R 30mm Adjustable Front and 24mm Non-Adjustable Rear Sway Bars
12. Brembo 380mm GT Brake kit
13. Forgeline 20x10” VX3C Concave Wheels with 275/30R20 Falken Azenis FK453 Tires
14. SPC Adjustable Front Control Arms with AWE Tuning Wiring Harness Relocation Kit
15. EuroGear Carbon Fiber Front Splitter
That’s not going to fit in our list. Although lots of it is fluff. Are the wheels light? I reckon they must be lighter than peelers which are around 30 lbs. The Brembo GT kit…are the rotors lighter than stock?
The only relevant mods are GIAC Stage 2, Intake, Catback with Downpipes, ColdFront, DSG flash
Wheels are about equal or maybe a slight bit heavier than the Stockers. Front brakes are also very close to stock weight- maybe 2-3lbs total at most…
Last time I checked 25.6 and 24.5 is 50.1 not 49 lol since you like to to suttle jabs all the time.
But like you said with Mistros LW rotors, all this is negligible
not sure why it’s damn though…it’s the same engine…same blower, which is being maxed out. The Q5 weighs what…4400 lbs? About 300 more than S4. That’s right where it should be really. It’s making probably 475 hp and 460 tq. That’s nuts.
24 for the wheels and 25 for the tires = 49 to me. Fractions, sure have fun. I guess they’re brand new 1 day old tires and not worn down. Oh wait they have 10,000 miles on them and are down 3/16" there’s a pound or two.
Very strange this obsession. It makes sense now though…now we know why you’re running off to the track on pump gas every 2 days…it’s because Mistro went 12.21 in his RS4 on pump.
Heaven forbid he should run catless and with no headwind. Will you cry if he goes faster? Should we ask God to edit your user account so Mistro’s timeslips don’t show up?
those sound like lots of guesses purporting to be facts…let’s get some real numbers down
Q5 weight from motortrend - 4336 lbs
coefficient of drag from a few sites - 0.33 (for perspective a B7 RS4 is 0.31)
wheels and tires…I will let you find that. I’ll be shocked if it’s over 61 lbs. They’re not super wide, and sidewall doesn’t weigh much relative to tread. The 20" wheels probably weigh around 30 lbs each…and the tires are what…27-28 if they’re conti sport or michelins?
