i’m still around on here. i haven’t seen any actual times added though. i heard a lot of us have been going to the track though! be sure to post all the relevant information (1/2 track speed, etc…). also, even though it’s not on there, temperature, altitude, fuel would be good extra information to put in.
hey guys. i’m back. i’m around here i just don’t have much time to look for times and then edit the table. if you’ve got YOUR OWN 3.0 liter times, post them as a reply and i’ll edit my original post. i’ll add a driver column if you guys want it!
also, edited the table with keaton@jhm’s run with their/his stock 3.0.
(how do companies do that anyway? does keaton own the car or does jhm? did he say?)
Track is closed or i would! I wanted to as soon as I got the TCU tune, but no such luck. It’s ok. I’ll take it when it opens next April, by then I should have dp’s and full exhaust.
A baseline would be good, but like I said track is closed already, by the time it’s open next year pipes will be on. That being said, if they aren’t I will go with just the ECU and TCU. I have access to some top notch pump gas up here, so I might be able to squeeze a slightly higher time, however I have no track experience so the extra oomph is probably a wash.
Oh and you can add zingo’s time, he ran 16.4 IIRC, it’s in a thread somewhere.
That is my best run yet. With TCU and ECU. I hopefully will get to the track maybe next week? Don’t hold me on that though. Once the dps are released I’ll go again. Then when I get a full cat back, then with race gas. I’m getting all antsy in my pantsy though.
People always doubt the “speed” of the 3.0, but the manual is geared really low, which helps it get moving semi-fast for the power/weight of the car. I’d guess, based on gearing, the automatic would never come close to that stock.
