That hood does look pretty damn nice.
thank you.
I was just thinking to myself I cant get to the track and set records but at least ill hold 2 records for sure.
- longest rs4 supercharger build in history.
- most expensive rs4 hood in history.
Just break in the clutch and break in the supercharger properly. Setting a record for ‘first patient thing Badtoyz has ever done with his RS4’ would be most impressive
ya fuck patience is not my strong suit.
anyhoo I finished the car completely today. first off I cant tell u how unbelievably powerful it feels. I feel like I own the fastest car in the world right now lol. a rolling third gear pull form 2000 to 8000 feels incredible. the power comes on fast and feels like it just keeps getting stronger and stronger as the revs climb. im so very very impressed.
the clutch feels firm but not too firm. I like it. I am getting a small amount of chatter when starting on a hill sometimes but im sure that will even itself out with break in.
the short shifter feels great forward and back but I feel like there is more play than there should be when in gear going side to side. also reverse feels like it barely gets in there and popped out on me twice today. might need a little tweaking.
the last modification i had to do.
http://i1270.photobucket.com/albums/jj615/Garrett_Hargreaves/Mobile%20Uploads/20150617_215312_zpsb8v71pal.jpg
here she is all buttoned up. everything in its home and the hood pins installed. im still not happy with how the hood sits even with the new hinges. im thinking the hinge holes need to bigger to allow the hood to sit down more.
http://i1270.photobucket.com/albums/jj615/Garrett_Hargreaves/Mobile%20Uploads/20150617_222214_zpsyvczgjsu.jpg
http://i1270.photobucket.com/albums/jj615/Garrett_Hargreaves/Mobile%20Uploads/20150617_222224_zpsxtgwxw9s.jpg
when i first started the car i got a shit ton of codes for things i forgot to plug in. i cleared them all and went driving today, the car was great and i got about 50 km in before i got the cel. i just cleared it and drove about another 50 km and got it back so i actually scanned it and heres what i got.
Wednesday,17,June,2015,22:10:27:00498
VCDS – Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
www.Ross-Tech.com
VIN: WUARU78E57N900137 License Plate: STAGE 1
Mileage: 154150km-95784mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WUARU78E57N900137 Mileage: 154150km-95784miles
Address 01: Engine Labels: 079-910-560-BNS1.lbl
Part No SW: 8E1 910 560 A HW: 8E1 907 560
Component: STG1 SC/V4 JHM ª0060
Revision: --H09— Serial number: XXXXXXXXXXXXXX
Coding: 01040009180F0160
Shop #: WSC 93008 999 83881
VCID: 2447CDB6E7DA0D012A7-8071
2 Faults Found:
004200 - Intake Air Switch-Over Valve (N335)
P1068 - 004 - Open Circuit
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 154129 km
Time Indication: 0
Freeze Frame:
RPM: 179 /min
Load: 68.6 %
Speed: 0.0 km/h
Temperature: 65.0°C
Temperature: 36.0°C
Absolute Pres.: 960.0 mbar
Voltage: 10.541 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 154153 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 99.0°C
Temperature: 37.0°C
Voltage: 11.938 V
Readiness: 0010 0100
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 G HW: 8E0 614 517 BD
Component: ESP8 quattro H06 0150
Revision: 00000000 Serial number: 00000000000000
Coding: 0004533
Shop #: WSC 06335 000 00000
VCID: 2B55268A8A04C279EBD-807E
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 2832
Coding: 00000
Shop #: WSC 00000
VCID: 6DD1E89227900C49B59-5106
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul ECE 0704
Coding: 01021
Shop #: WSC 65536
VCID: 3B7516CA296452F97BD-4B00
1 Fault Found:
01496 - Bulb for Fog-Lamps; Left (L22)
30-00 - Open or Short to Plus
Address 11: Engine II Labels: 079-910-560-BNS2.lbl
1 Fault Found:
000086 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
P0056 - 004 - Malfunction / Open Circuit - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 0
Fault Frequency: 7
Reset counter: 255
Mileage: 154139 km
Time Indication: 0
Freeze Frame:
RPM: 2721 /min
Load: 14.5 %
Speed: 71.0 km/h
Temperature: 94.0°C
Temperature: 34.0°C
Voltage: 13.335 V
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H12 3840
Revision: 91H12384 Serial number: 0036N001NW35
Coding: 0433607
VCID: 3C7715D67F6A55C1727-8069
Subsystem 1 - Serial number: 6332DRB402E04C26N
Subsystem 2 - Serial number: 6342DRB402E490B1P
Subsystem 3 - Serial number: 6352ARB401097FDC$
Subsystem 4 - Serial number: 6362ARB401088E58R
Subsystem 5 - Serial number: 63729RB4010A70258
Subsystem 6 - Serial number: 63829RB4010A70406
Address 16: Steering wheel Labels: 8E0-953-549-T.lbl
Part No: 8E0 953 549 T
Component: Lenksáulenmodul 0201
Coding: 04441
Shop #: WSC 06335
VCID: 44876D36549A2D010A7-4B00
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 931 G HW: 8E0 920 931 G
Component: KOMBI+WFS 4 H14 0030
Revision: 0030 Serial number: 00000000000000
Coding: 0023001
Shop #: WSC 93204 999 85775
VCID: 2C5725968C0AC541E27-5140
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0023001
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 00000
VCID: 71E9F4E23BA8E8A9911-4B00
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 J HW: 8E0 035 192 J
Component: RNS-E US3 H72 0200
Revision: 03S Serial number: AUZBZ7F2428587
Coding: 1358193
Shop #: WSC 02239 000 00000
VCID: 2B55268A8904C279EBD-517C
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CG
Component: Komfortgerát T7B 4035
Coding: 11896
Shop #: WSC 06335
VCID: 78FFC9C658D2B9E156F-4B1A
Subsystem 1 - Part No: 8E1959801G
Component: Tõrsteuer.FS BRM 0706
Subsystem 2 - Part No: 8E1959802G
Component: Tõrsteuer.BF BRM 0706
Subsystem 3 - Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000019
VCID: 285FD9869BF2E96106F-807D
Subsystem 1 - Part No: 8E0 941 329
Component: AFS-Modul links H03 0020
Subsystem 2 - Part No: 8E0 941 329
Component: AFS-Modul rechtsH03 0020
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 1358193
VCID: 2B55268A8904C279EBD-519A
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 A HW: 8E0 907 273 A
Component: Reifendruck 3 H04 0130
Coding: 0062523
Shop #: WSC 93008 999 59057
VCID: 2A5B238E86FEDB7110B-5140
1 Fault Found:
01521 - Sensor for Tire Pressure
002 - Lower Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
(no units): 0.0
Voltage: 12.10 V
(no units): 19.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 D HW: 8E0 919 283 D
Component: Parkhilfe 4-Kan H06 0010
Revision: 00H06000 Serial number: 00067802020605
Coding: 0000304
VCID: 316934E2AB28A8A9D11-515E
1 Fault Found:
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 128
Time Indication: 0
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 G HW: 8P0 862 335 G
Component: FSE_255x BT H21 0190
Revision: 00000001 Serial number: 00000000411328
Coding: 0011877
VCID: 3A7B13CE765E6BF160B-5124
End-------------------------(Elapsed Time: 07:05)--------------------------
so whats the intake air switch over valve? and whats the deal with the sensor for parking aid? as far as i can remember we don’t have park assist. seems the resistor for the one foglight bulb is faulty. and my o2 sensor code is b2s2 which iirc is passenger side rear sensor right? if that’s the case im pissed cuz that sensor is brand new.
Sorry about your codes… I’m not technically well versed in the RS4 enough yet to be able to help you out. I need to learn more!
But, I wanted to post and say that your car looks fantastic! (and it must be a ton of fun to drive when working…)
Well the possible good news is
B1 is the passenger side
B2 is the driver side
S1 is the very front sensor
S2 is the very back sensor.
So B2 S2 is the driver side rear.
The air change over sensor is on the air box it’s a little sensor you plug in still. Thanks for all the updates.
I thought that was the air box sensor. But plug it in where? The air box is gone. That’s if I can even find the plug.
I’m not overly concerned because I don’t think that sensor throws a cel. I’m just kinda pissed that my brand new o2 sensor that has less than a few thousand km on it is faulty. J bought it from ecs last year but because the car has been sitting so long there’s no way they will exchange it. I’m happy that my front o2s seem to be holding up though.
Sorry to hear about that shitty O2. They’re not exactly known to be robust parts.
Your car looks absolutely incredible though and I’m sure the power is insane. Also, I just want to say that that’s the best hood prop I’ve ever seen haha
I just went to get my sticker too and I waited too long So i require an etest so I ordered an o2 and ill be pulling everything apart to find the plug for the airbox flap now. Good thing i put everything together last night lol.
And ya totally rockin the snow brush hood prop.
That sucks about the 02. I had that happen. To me. I got brand new 02s installed them and one was bad. It is frustrating. That custom hood prop is car show winning material. If your a car guy who had at least one broom stick like hood prop in your lifetime.
lol true story.
I found the connector for the air box flap, I found the solenoid its supposed to be attached to. it was on the bracket for the sai pump I removed. I plugged it in and zip tied it up and no more code. I also removed the one resistor for the fog light on the driver side and just plugged it abck into the foglight and got rid of that code. all I have left now is the o2 sensor and that park assist which I didn’t even know I had.
Your RS4 is looking on point! Glad you found the problem, those sensors can sometimes be a BITCH
my o2 didn’t come today so Monday now. clutch break in continues… its nice and cool today tonight would be a good night for a pass… :
So I’m noticing now that my clutch engages right at the floor and if u Rev the car with clutch in and in first gear it starts to roll forward. Is this the sign of an issue or is this normal during break in. I never noticed this before today. I have about 200km on it now.
I’m gonna jack it up and follow jhms bleeding procedure tomorrow. If anyone has any input or help feel free to tell me. This is my first time bleeding the clutch in this car
Sounds like the pressure plate bolts are backing out. Either they weren’t patient putting it on, or they didn’t put loctite on, despite the instructions
Fuck sakes. I made him read the instructions with me and he swore up and down he loctited everything.
Well I won’t be drivin the car until I know what’s happening for sure now. I’ll try and bleed the clutch and see if that helps. If not It’s goin back in on Monday. Fuck. This is exactly why I can’t stand other ppl touching my car cuz I don’t know for 100 percent what has actually been done.
It sucks but you would be amazed how many shops just do things there way. This isn’t just a audi thing You can read across the other makes of cars and it’s the same story.
Mother fucker. If we pull the tranny and the bolts are loose and I don’t see red lock tight somebody’s gettin a right hook.
I would be more concerned that th PP was tightened down in evenly and he warped the springs. Make sure you also check that.
