Couple notes on the hood:
-The Vorsteiner hood will have provisions for the windshield washer nozzles, along with the hole for routing the wiring.
-At the front of the hood, there are 6 points where the rubber bumpers are installed.  The 2 at the very front aren’t adjustable, but the other 4 are…  That being said, all the Vorsteiner hoods I’ve seen are different in regards to which holes are actually cleaned out enough to thread those bumpers in.  On my first hood, I could only fit the two outer ones.  On my current hood, I’ve only got the two front ones.  Since you’re running hood pins, these won’t be much of an issue, but I just wanted to point that out so you’re not erk’d by it.
-For both the hinge bolts and latch bolts, don’t over-torque them…please don’t over-torque them.  There was a fella Saki mentioned that over-torqued the latch bolts and they failed.  His lawsuit is the reason Vorsteiner doesn’t make the B7 hood anymore…well, they will, but I think they quoted something asinine, like $4700 to make another one…
-I actually removed my center latch once I switched to hood pins.  It didn’t like locking, and I didn’t like dropping the hood from 2’ with the hood pins sticking up…  It’s your call which route you wish to go.
-When you look at the vents, the amount of material that remains is directly correlated to when the hood was produced.  The newer hoods have much smaller openings, as the leftover material acts as additional structure.  The early hoods were cut out completely and people complained of spider cracks in the resin.
-The A4 guys are generally the ones who have problems with these hoods & water.  The center vent lines up directly with the coil packs on the 2.0t and that’s what generally failed.
-I don’t know of anybody who’s had water/electrical trouble with this hood and a V8, but perhaps I just never heard about it.  I’ve had no issues, nor have the other 20 people I know with the hood, but we’re all in SoCal/AZ…which admittedly isn’t the best demographic to poll.  Personally, I think the guys who can’t adjust their bumper for sh*t are getting more water in the engine bay than I ever do with the hood…but again, I’m biased.
-When you’re installing the pins, be cognizant of the underside of the radiator support…as you adjust the pin height, you’ll hit the headlight housing quick, and need to chop off quite a bit of the extra pin to get a clean install.
