Any luck?
They found PP bolts in the bell housing, badtoyz murdered the tech, and now there is a man hunt for him…
just a guess
it’s not America though. So he may have punched the guy’s mouth loose, but not likely a murder.
LOL Murder happens everywhere, not just the land of the free
Take note that nowhere in my post did I say ‘murder only happens in America’ or ‘murder never happens in canada’.
The key to forming a strong argument is to avoid hyperbole and absolute terms like ‘never’ or ‘none’. I said ‘not likely’ as it is far less likely in Canada than it is in America. That’s simply a fact.
Here…enjoy.
http://www.unodc.org/gsh/en/data.html
Your country is nearly 3 times as likely to have a murder as Canada. That’s pretty significant, for a ‘sophisticated’ country!
Haha I don’t doubt that for a second.
We are extremely sophisticated, proof is in the pudding:
lol you guys are funny.
so we pulled the tranny and by we I mean me and the tech. I checked every bolt on the pp and the flywheel and everything was tight. the tech also marked every bolt on the flywheel when he put it in the first time and none had moved even a 32. I see no faults or issues with the parts and see no faults or issues with the installation. I ordered a new slave and a stainless line because that’s the only thing it could be unless its the master in which case I wont have to r&r the tranny a third time so slave and line first.
I took pics of everything if anyone sees anything out of the ordinary let me know.one thing that’s for sure is that the flywheel did not move. anything else that I should replace while its out?
its funny u said all that about killing the guy because once it was all said and done and we saw there was no mistakes the owner of the shop said thank you to me for keeping my cool. he said I know when u called me u were pissed and u said u were gonna punch my tech out but thank you for being cool about it all when u saw him. hes gonna let me slide on most of the labour for the tranny r&r so that’s pretty nice of them.
im glad the work was done properly and if its the slave or a weak line then its my own fault for not replacing them the first time around.
http://i1270.photobucket.com/albums/jj615/Garrett_Hargreaves/Mobile%20Uploads/20150624_175633_zpstuj2yfbu.jpg
http://i1270.photobucket.com/albums/jj615/Garrett_Hargreaves/Mobile%20Uploads/20150624_175618_zpsql0rpdwr.jpg
http://i1270.photobucket.com/albums/jj615/Garrett_Hargreaves/Mobile%20Uploads/20150624_175557_zps9hipqarw.jpg
http://i1270.photobucket.com/albums/jj615/Garrett_Hargreaves/Mobile%20Uploads/20150624_175551_zpsxxckure9.jpg
Good to hear!
Also, the flywheel bolts that are marked are not what cause this issue. It is the 6 pressure plate bolts that attach to the flywheel. A pressure plate bolt backing out by even a half turn will cause issue, as it allows the pressure plate to flex.
Also improper uneven tightening of the pressure plate bolts can screw up the springs. You need to make sure the spring fingers are still even.
i checked all 6 with a torque wrench they were all tight at 23 ft/lbs. ill take a closer look at the fingers tm. should i use Loctite on the 6 pp bolts too?
Yes, red #266 high temp loctite
ok i will make sure. ill go tm and put it back together myself.
is there an upgraded slave or should an oem one be fine? or let me rephrase is the metal slave any better than the oem? the threads i keep reading are indecisive and when everyone thought the slave was to blame for the sticky clutch issue.
We have always used the OEM slave.
Yes, red locktite is required!
Also use the OEM slave. I have the metal slave and SS line but there isn’t a worthwhile difference.
ok i will order an oem slave and a stainless line.
so the red loctite wasn’t used the first time on the PP bolts? explains the sensation -if they backed out a bit.
no it was used and the bolts were at the proper spec. I was just confirming that yes Loctite is to be used on those 6 bolts. everything they did they did exactly as per the instructions. im thinking the line is flexing under the stress of the stronger pp or the slave is beginning to fail. probably the first time the clutch has been done so its all 8 years old.
im just happy that the clutch is ok. I still need to recheck the fingers on the pp though.
I have a question for everyone with the trio installed. what kind of side to side play do u have when in gear. I feel like I have too much but maybe that’s just because my g35 doesn’t move at all side to side.
I still don’t have reverse right so I need to make some more adjustments. im fairly confident now though that moving the base forward will get me reverse where it needs to be.
Bad Toyz, Bad Toyz whatchu gonna do when they come for you?
I bet you get that a lot. I start singing it everytime i see your SN.
